Troubleshooting 8" Screen
Old 09-01-2016, 02:11 PM
Hawk6man
Hawk6man's Avatar
Default Troubleshooting 8" Screen
Hello all,
Base GT - So I bought one of the aftermarket 8" screens to replace the 4". I actually had it hooked up and working, but decided to add amp and stuff. I installed LOC back behind the stereo; after having that hooked up , and putting it all back together, now the screen won't turn on. The speakers are working I think; I hear loud *** chimes that I haven't heard, but no music, screen... It might be worth mentioning that I soldered...
All the harnesses are snug and all the wires look fine. I checked fuses 32 and 33 inside, and they are good. One fuse was blown under the hood, #54 Auxiliary power point, but changing that did nothing.
I'll still pretty new at this, and pretty frustrated I can't get all my stuff going. Any help is appreciated.
Thanks.
Hawk6man is offline
Old 09-01-2016, 02:33 PM
jz78817
jz78817's Avatar
Originally Posted by Hawk6man
Hello all,
Thanks.
what touchscreen unit did you install, and what install/dash kit did you use? If you're hearing chimes, are there any warning messages on the cluster? you could have pinched/broken one of the CAN wires.
jz78817 is offline
Old 09-01-2016, 04:13 PM
Hawk6man
Hawk6man's Avatar
Default Screen
Man, I kept trying to reply on my phone, and it was telling me I didn't have enough characters lol.
My aftermarket unit is just a bezel and the 8" screen. They're lookalikes to the 16 premium mustang. It's put on the new harness and plug and play.
That's a good idea about the chimes; those are new. I'll check the cluster later after work.
Thanks You.
Hawk6man is offline
Old 09-01-2016, 04:59 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Did you have the battery disconnected while you were soldering things? Could've shorted something out.
Derf00 is offline
Old 09-01-2016, 05:11 PM
Hawk6man
Hawk6man's Avatar
It wasn't disconnected. I guess my reasoning was the wires I was working on weren't connecting to anything.
I was soldering the loc to the speaker wires from the harness that wasn't plugged. I had already cut the other end of the wires from the speakers and ran new wire.
Hawk6man is offline
Old 09-01-2016, 05:15 PM
Hawk6man
Hawk6man's Avatar
I guess I should mention it's a '16.
Hawk6man is offline
Old 09-01-2016, 10:27 PM
Hawk6man
Hawk6man's Avatar
There's no warning on the instrument cluster.
Hawk6man is offline
Old 09-02-2016, 10:35 AM
Hawk6man
Hawk6man's Avatar
My friend told me I need to check power, ground, and constant to the screen, if all those wires are good, then the screen should be turning on...If the screen doesn't turn on, then it must be the problem. I think I know how to do this but I don't know. Snip the wires, then do some checking with a voltage reader?
Hawk6man is offline
Old 09-02-2016, 04:58 PM
Hawk6man
Hawk6man's Avatar
Anyone know what the constant wire is going to the audio?
Hawk6man is offline
Old 09-18-2016, 01:47 PM
Hawk6man
Hawk6man's Avatar
Found the problem. The harnesses that came with new screen had a little plastic piece that stuck, and inside was a fuse. I never thought the harnesses would have a fuse; neither did a professional I went to. Well, it was blown, little 5 amp fuse, and that immediately fixed the problem.
Hawk6man is offline
Redneck1465
03-08-2016 02:04 PM
Lee1911
03-05-2016 05:34 PM
Lee1911
03-03-2016 08:05 PM
buttonz75
02-26-2016 10:21 PM
ODiST
02-23-2016 10:48 AM
Quick Reply: Troubleshooting 8" Screen
