Cut off
Cut off
I was wondering if any your Bullitt's have had this problem. As soon as you turn the ignition on the reves then dies out. I think it is a problem with the injectors but i'm not sure. If you have had this happen to yours tell me what you had done to repair. Thanks in advance.
RE: Cut off
Yea I would definitely check your MAF first. It could be your injectors, but I highly doubt that. If it starts and then dies a couple of seconds later more than likely something is not letting it get enough air. Hope this helps!
jwog666
12-27-2021 08:09 PM
