Bullitt Suspenion Package ?
I have a 94 GT, and I am lookng at a suspenion package that consists of stock Bullitt components.
http://www.buyfordracing.com/shop/pr...roducts_id=458
My questions is: How do stock Bullitt's handle? My car is a DD. I am not looking for all out handeling.
How does it ride? I am not looking for a jarring ride. Smooth and forgiving enough for daily hwy drives?The springs rates are 600 front, 250 rear.
$450 for new shock/struts, springs, swaybars, all factory designed to work together sounds good to me. I there anything I should be aware of?
RE: Bullitt Suspenion Package ?
They handle good, it's not any ruffer then a stock gt, may be a little stiffer just because it's new. Will it work on a 94? That would be my only question. I'm not sure about that.
It will fit. It says right in that discription that if you install it in a 94' it will lower the car an inch, as opposed to 3/4s of an inch in a 99-04. As far as ride and quaility its probaly the best bang for the buck you can get. I say go for it!
I am pretty intersted in the package,andtheownerssay the cars handle/ride great, so that settles it.
Correction: its $425.
How much do you think it is to get it installed? I wouldnt think much more than a strut/shock install, considering thay have to remove the front springs any way.
One last question: Do the Bullitts have the rearend slightly higher than the front? Mines like than, and I dont want it to change if lowered.
Shouldnt be to terribly much. It would be a simple driveway install assuming you have no problems with springs. But as far as the drop, i think mine sits pretty much level. But you could rotate the rear springs a little to bring it up a little. Just be sure they are the same or the car will lean to one side like you gota fat chick in there. lol
