Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > Bullitt Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-24-2009, 11:49 PM   #1
cezr75
Vehicle: 2001 mustang bullit
Default 01 bullit is idling to high
hi everyone
i own a 01 bullit. i recently replaced a faulty iac valve. the car ran fine for a couple of weeks. now however it is idling at around 900rpms as opposed to 750 rpms like it normally would. i also replaced the tps disconnected the battery overnight to reset the computer checked for any vacumm leaks and cleaned the throttle body. it is still idling to high. any suggestions would be greatly apreciated. thanks guys
cezr75 is offline   Reply With Quote
Old 09-25-2009, 02:05 AM   #2
5.0 85 GT
what other mods do you have done tot he car? and what did you clean it with? and how is your MAF sensor?? you could also check the gasket on the IAC to make sure it is still good, if not you might have a slight vacuum leak??
__________________
Big Snake, Little Bite...Full Bolt-On 97 Cobra, Bored .30 over...Need Kenne Bell
-1986 IROC-Z-SOLD
-1985 GT T-Top-SOLD
-1994 GT-SOLD
-2002 GT-SOLD
-1997 COBRA-LOVE!!
-1988 Mercury Cougar Bostonian, 5.0 60k Mile Peach
-1985 GT-Carb'd Special, Bolt on's and a t-5 n Sunroof!
-1993 Ford F-150 4.9I6 5 Speed-WON'T DIE
5.0 85 GT is offline   Reply With Quote
Old 09-25-2009, 06:29 PM   #3
cezr75
hey 5.0 gt
the car is stock. i also replaced the gasket when i installed the new iac and i cleaned the maf with the special cleaner they sell at the auto parts store.
Old 10-26-2009, 06:18 PM   #4
TRUEBLUE3934
Vehicle: 2001 Ford Bullitt Mustang
Quote:
Originally Posted by cezr75 View Post
hey 5.0 gt
Did you ever figure out what was causing your idle troubles? I am having issues with my idle now. I just replaced the IAC to eliminate it from potential causes. I just had cams and long tubes installed and the tech doing my custom tune could not get the revs to stop hanging and also the car will sometimes choke off at idle. I am a little upset with how it runs right now. I did not have these issues until I took it in for the mods and tune. The cams are Hitech StageIIs and are not too radical. I don't think that is the root of my troubles here...
Any ideas???
TRUEBLUE3934 is offline   Reply With Quote
01, 2001, 46, air, body, bullit, bullitt, flow, high, iac, idling, mass, mustang, reviews, sensor, throttle
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
