Bullitt Mustangs
2001 Bullitt - Load moan while driving then stall
Old 06-02-2016, 01:27 PM
darsky
darsky's Avatar
Default 2001 Bullitt - Load moan while driving then stall
I have had an intermittent problem for some time that has recently become quite regular. I will hear a moan (either while driving or idling) that starts quiet and gets louder. If I let it run its course, the engine will smoothly/calmly stall. Then I can start it up again right away with no hesitation and it runs fine.
If I give it some throttle rather than letting it run its course, it will not stall and the sound stops with the engine still running well.
I have cleaned the MAF sensor and air filter (K&N). But that did not help.
I have not found this exact behavior discussed anywhere online. Any idea what might be causing it?
Thanks for any help.
darsky is offline
Old 06-02-2016, 03:58 PM
jwog666
jwog666's Avatar
sounds like an IAC "hoot" clean it up and see if that helps
jwog666 is offline
Old 06-02-2016, 04:24 PM
darsky
darsky's Avatar
Oh, wow! I googled "IAC hoot" and found a video that sounds exactly like it. I will start off by cleaning the IAC and will return with an update.
darsky is offline
Old 06-03-2016, 11:50 AM
darsky
darsky's Avatar
So I cleaned the IAC yesterday. It was so dirty inside, I couldn't remove all the grime. It seemed better for a little bit. But last night it got worse.
I am definitely going to replace the IAC right away and report back here.
darsky is offline
Old 06-06-2016, 01:48 PM
darsky
darsky's Avatar
RESOLUTION: I ordered a new IAC (the one meant for the Bullitt, not the GT) from Amazon on Friday with guaranteed delivery on Saturday. It arrived before noon on Saturday and I swapped it out. I also disconnected the battery while doing this as some have suggested the computer needs to reset its calibration of the IAC when it is cleaned or changed. So all bases were covered. It has been running perfectly since.
There are definite differences between the GT and the Bullitt IAC valves. So, while the GT will work on a Bullitt, I suggest making sure to get the correct item for your Bullitt (Motorcraft CX1808 Idle Air Control Motor) when replacing an IAC unit.
darsky is offline
tgprof
03-26-2016 07:53 PM
jgull1g
03-23-2016 01:49 PM
mitchell1963
03-14-2016 12:32 PM
Offendant
03-11-2016 10:03 AM
UltraBlue91'
03-07-2016 07:01 AM
Quick Reply: 2001 Bullitt - Load moan while driving then stall
