What are you working on?
Old 02-26-2017, 12:19 AM
  #11121
socal57chevy
socal57chevy's Avatar
Originally Posted by Sleeper_GT
The struggle is real my friend
Struggle bus....Heck, I drive the friggin struggle bus.
socal57chevy is offline
Old 02-26-2017, 03:51 AM
  #11122
Sleeper_GT
Sleeper_GT's Avatar
I'm just waiting to get home and work in my ride. I need a little automotive struggle in my life right now....lol
Sleeper_GT is offline
Old 02-27-2017, 08:09 PM
  #11123
alan0614
alan0614's Avatar
I am sure you do need a little bit of a supercharged ride right now.
alan0614 is offline
Old 02-28-2017, 07:43 AM
  #11124
Detector
Detector's Avatar
Cleaning up a 10 year old restore. It's a 1964.5 that originally is a U code (6 cyl) but has had a 302 installed. Automatic, and everything seems good for a 10 year old restore job, but it's starting to leak fluid from I think both the engine and trany. Needs a little cleanup to call it finished. Runs and drives great though.
Detector is offline
Old 02-28-2017, 08:12 AM
  #11125
Sleeper_GT
Sleeper_GT's Avatar
Beautiful ride!
Old 02-28-2017, 01:55 PM
  #11126
CPTCO
CPTCO's Avatar
Fantastic
CPTCO is offline
Old 02-28-2017, 09:04 PM
  #11127
alan0614
alan0614's Avatar
Very nice
alan0614 is offline
Old 02-28-2017, 09:54 PM
  #11128
DK Pony
DK Pony's Avatar
I am finishing up the restoration of the Triumph Gauges.
Most of them were pretty straightforward..Disassemble, clean, reassemble.
1968-1972 used an ammeter. The original alternator is a 30 amp unit and barely had enough power to run the lights. I am planning to upgrade my alternator to a 60 amp unit. I didn't want to use a volts gauge so I decided to see what I could do with the original ammeter.
Because all power runs into the ammeter the 60 amp alternator would easily burn out the ammeter. All of the aftermarket ammeters would look really out of place in the dash so....
This is the 60 amp ammeter I started with.
This is what the insides of the 60 amp ammeter looks like after I got it out of its case.
You can see the black cylinders to the left and right of the needle. These are made of plastic and were originally used to fasten the face to the gauge. These had to be trimmed to allow the 30 amp face to sit far enough into the case.
I happened to have a spare 30 amp ammeter that was toast. Here is the insides of it.
I cut the needle and the parts of the 30 amp away to create a plate for the back of the 30 amp case. I wasn't planning to use this case until I decided to go with a 60 amp alternator. So the paint that is in it isn't the best. I will blast and clean and paint the case much better once I find out if this will even work.
Here is the 60 amp mounted in the 30 amp case. I am using a spare case and the face from an old gauge that is toast just to mock all of this up and see if it will even work.
Here is the 60 amp mounted in the 30 and with the original face. It is starting to look like this will actually work.
I straightened the needle to give it more length and painted it white.
And it actually worked. This is the 60 amp ammeter mounted inside the 30 amp case.
Now I will use the good face that I have and clean and paint the bezel as well as blast and clean the case and glass.
And here it is ready to be put on the shelf for final assembly and installation.
DK Pony is offline
Old 02-28-2017, 10:03 PM
  #11129
CPTCO
CPTCO's Avatar
Very cool. Great work.
CPTCO is offline
Old 03-01-2017, 09:52 AM
  #11130
alan0614
alan0614's Avatar
Nice work Dave.
alan0614 is offline
Quick Reply: What are you working on?
