What are you working on?
Old 10-24-2014, 07:30 AM
  #8661
Shellback
Shellback's Avatar
Enjoy my Roush
Shellback is offline
Old 10-24-2014, 10:25 AM
  #8662
alan0614
alan0614's Avatar
Originally Posted by Shellback
Enjoy my Roush
Larry...........you have Borlas!!!!
alan0614 is offline
Old 10-24-2014, 11:00 AM
  #8663
Jeffk
Jeffk's Avatar
Location: Thomasville, NC Where we beat headers into submission!!
You're just going to the wrong shops lol. GL with the install, those parking brake cables are a b****.
really? I didn't think they were that bad. Of course since I kept getting bad LCA bushings I changed those F'ers like 6 times.
HAHAH! Whoops.
Jeffk is offline
Old 10-24-2014, 02:09 PM
  #8664
clowe1965
clowe1965's Avatar
HAHAH! Whoops.
Well maybe I disassembled them wrong but they were about as much of a pain as reassembling a drum brake.
clowe1965 is offline
Old 10-24-2014, 02:23 PM
  #8665
Jeffk
Jeffk's Avatar
Not sure what you disassembled. Just release the brake inside car, pull clip off of cable at the wheel, pull down on cable to remove from bracket, disconnect from actuation arm.
Regarding the Jeep and the pinion nut. Took it to a diesel/ off-road shop and they "snugged" the nut up... not sure how confident I feel in that fix so I am currently at the house with the rear cover off. Things look ok inside. The spider gears are a litter chewed up but the Jeep has 168k on it. No big chunks missing out 9f the ring or pinion so I'm putting it back together, adding fresh fluid and hoping for the best. Oddly the old flid did not sMell like gear oil....wtf?
Jeffk is offline
Old 10-24-2014, 05:05 PM
  #8666
CPTCO
CPTCO's Avatar
Jeff, I've never seen that. Guessing it's just age related. I'd probably throw some locktite on the nut.
CPTCO is offline
Old 10-24-2014, 06:30 PM
  #8667
Jeffk
Jeffk's Avatar
I think that the driveline vibrations might have worked it loose? I don't know. I've never seen it before either. Hopefully they did put some loctite on it.
Jeffk is offline
Old 10-24-2014, 07:47 PM
  #8668
clowe1965
clowe1965's Avatar
There was a spring involved that kept flying off lol. Owell. Not sure about that off road shop either. Guess I need to pick up gear installs for a new skillset.
Old 10-24-2014, 07:55 PM
  #8669
Jeffk
Jeffk's Avatar
Its been awhile since I've done LCAS so I am probably forgetting something.
I would really like to learn how to install gears.
Jeffk is offline
Old 10-25-2014, 08:09 AM
  #8670
audioAl
audioAl's Avatar
Gear installs are complicated, but if you race at the track, learning will save you money!
audioAl is offline
Quick Reply: What are you working on?
