Mustang Fuel Filler Pipe Seal Installation Video 1999-2004 - MustangForums.com
CJ Pony Parts We carry Ford Mustang parts for every Mustang built from 1964 to present. CJ's has everything you need to restore your Mustang or make it the performance & aftermarket styling machine you always dreamed of!
Old 10-18-2013, 10:10 AM   #1
Steve@CJPP
Platinum Sponsor
Steve@CJPP's Avatar
Default Mustang Fuel Filler Pipe Seal Installation Video 1999-2004
2R3Z-9072-AA Mustang Fuel Filler Pipe Seal 1999-2004 | CJ Pony Parts
This oem replacement fuel filler pipe seal is for your 1999-2004 Mustang and seals the connection where the filler pipe goes into the fuel tank. If your car leaks fuel anytime you put a half tank or more of fuel in it, this very well could be the culprit.
For installation, you'll want to lower your fuel tank and separate the tank from the fuel filler hose. Remove the original fuel filler pipe seal, clean the area where the new seal will go, and then put your new seal into place. Return your tank to its correct location, and your installation is finished in about an hour.
Fuel Filler Pipe Seal 1998:
F8ZZ-9072-AC Mustang Fuel Filler Pipe Seal 1998 | CJ Pony Parts
Fuel Filler Neck Tube Seal 1981-1997:
Mustang Fuel Filler Neck Tube Seal 1981-1997 | CJ Pony Parts
Steve@CJPP is online now   Reply With Quote
1995 Mustang GT- 8.8 Overhaul Urambo Tauro 5.0L (1979-1995) Mustang 22 09-07-2015 12:47 PM
P0148, VERY DESPERATE. Please help. mstahoo SVT Forums 9 08-16-2015 09:12 AM
Replacing Fuel Fill Grommet vbonina V6 (1994-2004) Mustangs 6 08-11-2015 02:51 PM
Just swapped motor exhaust want fit daytooday Motor Swap Section 2 08-11-2015 09:22 AM
Off road mid pipe questions BlackShelbyGt500 2005-2014 Mustangs 14 08-10-2015 11:50 AM
cj pony parts, fuel tank, install, seal, video
