RE: Here's a picture of my engine bay, where is yours?
Well I posted a pic of the 69 Mach 351C earlier (see below):
Now here is the 67 390 GT BB, stock with holley 4160 carb, pertronix ignition and wires, accel cap, and k&n filter. This is still a work in progress as you can see:
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Here is mine. Can't remember what paint we used for the engine bay. It was done back in1994. It is a very good paint though. I know it was like what factory ruberized coating that theyused back then. Specs first:
342 STROKER.
SCAT STROKER KIT 5.4 FORGED H BEAM RODS AND PROBE FLAT TOP PISTONS.
302 BLOCK STANDARD BORE.
10:2:1 COMPRESSION.
NITROUS OXIDE SUPER POWER SHOT/100HP JETS.
MELLINGS HIGH VOLUME OIL PUMP.
PETE JACKSON "QUIET" GEAR DRIVE.
CAMSHAFT INNOVATIONS CUSTOM GROUND TIGHT LASH SOLID ROLLER CAM
VICTOR JR.INTAKE
TOTAL ENGINE AIRFLOW TRICK FLOW TWISTED WEDGE HEADS, FULLY CNC PORTED 205cc INTAKE RUNNERS 60cc COMBUSTION CHAMBERS. 2.02 INTAKE VALVES 1.60 EXHAUST VALVES.
FLOW SHEET:
INTAKE: EXHAUST:
.100 71 .100 52
.200 145 .200 105
.300 219 .300 146
.400 273 .400 180
.500 305 .500 209
.600 315 .600 228
COMP CAMS 1.6 PRO MAGNUM ROLLER ROCKER ARMS,MANLEY PUSHRODS.
HOLLEY 830CFM CHOKELESS RACING CARBURATOR, HOLLEY 110GPH HIGH PERFORMANCE MECHANICAL FUEL PUMP, WITH ELECTRIC RED HOLLEY STREET PUMP BACK BY FUEL TANK.
MSD DIGITAL 6 IGNITION, MALLORY DISTRIBUTOR, TAYLOR WIRES.
JET HOT COATED HOOKER COMPETITION 1 5/8 HEADERS 3inch FULLY MANDREL BENT DR. GAS X PIPE KIT WITH HOOKER MAX FLOW MUFFLERS.
FEL-PRO GASTKETS, AND ARP FASTENERS THROUGHOUT.
POWERMASTER 140AMP ALTERNATOR.
__________________
1968 Mustang 342 Stroker TEA 205 CNC Trick Flow Track Heat heads Camshaft Innovations custom Solid roller cam 1.6 roller rockers Victor Jr intake 830cfm Holley 10.3-1 comp. Hooker long tubes Dr.Gas 3 inch X pipe kit.
Location: Originally Iota, Louisiana in San Diego now..
Quote:
ORIGINAL: Sean W.
Soaring, i made the EXACT same thread as this a couple months ago, it was stickied on the top of the forum, but i guess you took it off...
I knew it,, Someone find that thread and put it back up there,, this one is good, but that one was loaded..It should have never been pulled off the top.. It was like my morning coffee...
__________________
69 Mustang Grande'
351W Holley 670
Edlebrock Performer Cam/Intake
Hooker Competition Headers
Dual Flowmaster 2.5" 40's with a H Pipe
FMX Auto / 9 Inch Rear w/2.75 Gears
Motor was put in 10 yrs ago and has never been pulled since.
It currentlyhas about 10,000 - 11,000miles onit.
Ford Racing 5.0 HO Roller Motor(Crate)/B303 Cam/1.7 RR's
TFS Twisted Wedge 205 Heads/Ceramic Coated Tri-Y Headers
Edelbrock Performer RPM/Holley 650 DP/Milodon 8qrt oil pan
Mallory distributor/MSD Blaster coil/Holley electric fuel pump
Griffin aluminum radiator/Billet Export Brace/Monte Carlo Bar
