Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-24-2009, 09:47 PM   #1
demarchi411
Vehicle: 1966,ford,mustang
Question 1966 mustang leak?
I have a leak on my 66 and its in the cowl. How would you repair the leak?
demarchi411 is offline   Reply With Quote
Old 03-24-2009, 10:50 PM   #2
EZFEED
EZFEED's Avatar
Vehicle: 1967 Mustang convertible
Do you feel like cutting the vent area out? Its not that bad of a job actually, I did a 66 coupe by removing the windsheild and fenders then cutting the top out and drilling the spot welds on the windsheild lip.
Used POR-15 and chopped fiberglass. Brushed out the inside, got all the old caulking out, then applied a coat of POR-15 and laid the fiberglass over the area. You can use it just like resin and just add the chopped fiber like you would if you were using the resin. Go around the collars and coat the entire inside.
Is it the collars that are leaking or do you have leaks in the corners?
Some places sell plastic hat looking repair collars. That will work for a time but either way, once the cancer has set in topside you cant get to it, its only a matter of time till your whole cowl area is rusting out. Your best bet is to cut the top out and fix the area then rustproof it.
__________________
1967 convt "under construction"
http://img.photobucket.com/albums/v4...0cancer/p1.jpg
1923 Model T Ford roadser "almost done!"
http://img.photobucket.com/albums/v4...Picture146.jpg
1969 M35A2
http://img.photobucket.com/albums/v4...s/EZM35A21.jpg
1976 PLDvK 53/59 (one of three in the U.S.)
http://img.photobucket.com/albums/v4...s/EZPLDVK1.jpg
"Collector of old machines, tractors, and all sorts of other crap"
EZFEED is offline   Reply With Quote
1966, 1967, 66 mustang, air, base, carb, classic, convertible, cowl, intake, leak, leaking, leaks, mustang, patch
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
