a little wiring help
Old 06-27-2009, 09:57 PM
crismans
crismans's Avatar
Default a little wiring help
Someone installed a cheap set of aftermarket gauges in my '67 coupe and I'm wanting to reconnect the car's original gauges. Does anyone know what color wires went to the temp and oil pressure senders? Plus, just to be sure,where were these senders located?
Thanks!
crismans is offline
Old 06-28-2009, 11:28 AM
Oxnard Montalvo
Oxnard Montalvo's Avatar
Here's a link to the wiring diagrams found in the FAQ section.
1967 Mustang Wiring.
The diagram can be zoomed in on, the color codes are there.
The temp. sender is on the intake manifold just behind the distributor, the oil sender is mounted on a post in front of the oil filter.
Oxnard Montalvo is offline
Old 06-28-2009, 03:36 PM
crismans
crismans's Avatar
Thank you very much! And thanks for not raking me over the coals for not reading the FAQ section first as I should have done!
I'm afraid I'm being very slow, however. After looking at the appropriate schematic (the first thing it mentions is temp and oil senders), I can't find the senders on the schematic to locate the appropriate color. What am I missing?
crismans is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: a little wiring help
