Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-30-2009, 11:52 AM   #21
THUMPIN455
THUMPIN455's Avatar
Vehicle: Too many to list, 30+
It looks better in pics than it is, the quarters were bashed pretty bad before I cut them off, it moved the upper part that I welded to around. So its going to take a good bit of mud to make this thing straight. Im trying to keep it thin, but it is really annoying me with how its coming together. Looks like it might get painted yellow or white to hide the bad spots.
__________________
POD and Cougar progress pics:
71 Pit of Despair Mustang
67 Cougar
THUMPIN455 is offline   Reply With Quote
Old 07-31-2009, 02:05 AM   #22
THUMPIN455
THUMPIN455's Avatar
Spent today bumping the quarters around, grinding down the welds, and making the door gaps a little closer than half an inch. The drivers side quarter just didnt fit right, it was completely messed up, apparently it was stamped poorly and it required a ton of work to make it fit.
Well anyway it has some filler on it, should be cured enough to sand by tomorrow, didnt take any pics of that thought. It still needs a bit more to fill in some low spots I couldnt get to because of bracing behind the quarter. the pass side came out much better than I thought it would, I had a 3/8" channel where the quarter was bent and the replacement had a weird bend to it. Managed to get that moved back and stiffen the entire panel considerably. Not only did this thing have rust, it was also hit on every corner, some worse than others, so it makes things a challenge to fit.
This is the gap I needed to fill in, the front edge was off from the rest of the panel, its like the wheel lip was put in the wrong place, or the wheel house was stamped wrong moving the quarter back too far. Just a pain in the rear.
Here is the gap filled a bit prior to adding body filler. I didnt want to have half an inch of filler in the door jamb, so I used scrap metal to fill it in.
__________________
67 Cougar
Old 07-31-2009, 02:09 AM   #23
Canary94GT
1965 Ford Mustang
My Garage
Canary94GT's Avatar
Vehicle: 94 Ford Mustang GT
Wow great job filling in that gap Thumpin. Though I wish you didn't have to.
__________________
1965 Wimbledon White Mustang Inline-6 200
1994 Canary Yellow Mustang GT 5.0
PSN: GreatWalrus
Videos
Voted as best sig quote of 2008
Live in Washington and own a Mustang? Join this group!
Canary94GT is offline   Reply With Quote
Old 07-31-2009, 02:28 AM   #24
4reboy
4reboy's Avatar
Vehicle: 1969 Mach1
Looks good to me! how much more welding is needed before filler, primer, and blocking begins?
__________________
1969 Winter Blue Mach 1 M-code - mine
1969 Mach 1 428 R-code - dad's new project
1971 Mach 1 H-code - dad's (for sale)
Classic ROTM 2009 winner thanks everybody
4reboy is offline   Reply With Quote
Old 07-31-2009, 11:47 AM   #25
THUMPIN455
THUMPIN455's Avatar
Quote:
Oh just the entire front end, the trunk floor, and the rear tail light panel. I only mocked up the engine bay with tack welds to see if the fenders will bolt on in the right place. So I need to get to work on aligning the fenders and moving the radiator support and patches ahead of the shock towers around so the door gaps arent 3 inches and the hood fits.
Still have to do something about the cowl, might just weld in a nice flat piece so it drains outside the car, who needs ventilation right? This thing has windows. Then there are issues with the floor and toe boards, need patches for most of them. The doors need a bit of work, just a couple small rust spots to deal with in the bottom jamb.
Once the engine bay is final welded, then I am either building or buying a rotisserie so I can get to the bottom and make that nice under there. If I can scrape up the money I wont have to build it, right now it looks like I am building it.
__________________
67 Cougar
Old 07-31-2009, 01:49 PM   #26
GA_Mach1
GA_Mach1's Avatar
Vehicle: 71 Mach1 m-code
I was going to ask how your cowls were, but that explains it. Mine are shot, the vent hat was so bad, I was able to just pull it out by hand. I am trying to figure out the best way to replace the hat, might make something out of plastic, that wont rust. The cowl cover looked like swiss cheese and there is no replacement for that either, which meant grinding, welding and filler.
__________________
the 71 pictured is not mine, it is only a representation of what it will look like.
GA_Mach1 is offline   Reply With Quote
Old 07-31-2009, 05:58 PM   #27
4reboy
4reboy's Avatar
Vehicle: 1969 Mach1
THUMPIN, sooo you'll be done in a week or two?
I look forward to seeing the continued progress
__________________
Old 07-31-2009, 06:50 PM   #28
THUMPIN455
THUMPIN455's Avatar
If I could afford the parts I need to finish it, such as the entire front suspension and everything under the hood except the engine, then I figure it would take me roughly a month to complete it from where I am today. I just slathered some mud on the quarters today, probably headed back out to do some floor welding. Or I might stay in the house and play some Call of Duty 5 on the PC instead.. decisions decisions...
__________________
67 Cougar
Old 08-05-2009, 01:45 AM   #29
THUMPIN455
THUMPIN455's Avatar
Got some mud on the quarters, its still relatively thin even though it takes up a big swath of metal. Its rough shaped so I can add some later if needed when the primer is on. I might get to primer this week, I sure hope so. It would be nice to have most the metal work done on this thing. Here it is with mud on it.
__________________
67 Cougar
Old 08-05-2009, 06:48 AM   #30
andrewmp6
Now people see why most of us don't like remade sheet metal.
andrewmp6 is offline   Reply With Quote
69, door, firebird, jamb
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
