Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-27-2009, 09:19 PM   #1
photolabgirl77
2005 Ford Mustang
My Garage
photolabgirl77's Avatar
Vehicle: 1965 coupe, 1992 5.0 LX vert Feature Car, 2005 Supercharged GT
Default Hey guys, checking in with ya
Sorry I have been so busy. I havent really been on here much lately.
Well everytime to start the 65, I have to pour gas in the carb. Then it well run fine.
Is this a problem with the choke?
__________________
Go to the ROTM section its all new
My Mustang exploding on the highway like a slug from a .45 True death 400 horsepower of maximum performance piercing the night, this is Black Sunshine /July 07 Ladies ROTM
photolabgirl77 is offline   Reply With Quote
Old 07-27-2009, 10:02 PM   #2
Canary94GT
1965 Ford Mustang
My Garage
Canary94GT's Avatar
Vehicle: 94 Ford Mustang GT
Have you tried pumping the gas pedal to get gas into the carb?
In my 73 f-100 I had to pump the gas pedal like 30 times to get enough gas into it to start it. I fixed this by finding there was a vacuum leak in my crusty old accelerator pump on the carburetor. Replaced the accelerator pump diaphragm (piece of cake and less than $10). Now it starts up right away and I may have to pump the pedal once if it has sat for a while.
Another symptom of a bad accelerator pump diaphragm is gas leaking around it.
__________________
1965 Wimbledon White Mustang Inline-6 200
1994 Canary Yellow Mustang GT 5.0
PSN: GreatWalrus
Videos
Voted as best sig quote of 2008
Live in Washington and own a Mustang? Join this group!
Canary94GT is offline   Reply With Quote
Old 07-27-2009, 10:21 PM   #3
BA Mustang
ROTM Moderator
1967 Ford Mustang
BA Mustang's Avatar
Vehicle: 1967 Mustang Coupe
Send a message via AIM to BA Mustang Send a message via Yahoo to BA Mustang
I usually have to pump my car once or twice to start it.
__________________
ROTM November!
Own a red mustang join this group: Red
Own an I6 mustang join this group: I6
BA Mustang is offline   Reply With Quote
Old 07-27-2009, 10:48 PM   #4
THUMPIN455
THUMPIN455's Avatar
Vehicle: Too many to list, 30+
The carb is probably leaking down while it sits, it could also be the accelerator pump not working. If its every feaking time, like even when going to the store, shut it off and still have to dump fuel, well accel pump is a good place to start. If its overnight or after a week, then the carb is leaking fuel down the intake.
Lastly the fuel pump could also be losing its prime, meaning there is an air leak somewhere in the pump itself, or the line from the tank.
An electric pump can help with symptoms, you can fill the carb easy by running the pump before cranking. Still if there is an air leak in the line, putting pressure into the fuel line will show you where it is, real quick like with a big mess. If the accel pump isnt working or the carb is leaking down, rebuilding the carb is the right way, but an electric pump would fill the carb after it leaks.
Check the choke by removing the air filter assembly after the engine is warm or has been running for about ten minutes. It should be open. Before you start the car, pump the gas once to set the choke (provided it is electric or heated and not manual with a cable) and verify it is actually closed, if it is open then the choke isnt working. Keep in mind if its a hot day, say over 80F you shouldnt need a choke to start the car, unless its a cold blooded Dodge 318.
__________________
POD and Cougar progress pics:
71 Pit of Despair Mustang
67 Cougar
THUMPIN455 is offline   Reply With Quote
Old 07-27-2009, 10:52 PM   #5
WildMustang351
2008 DODGE Ram 2500
My Garage
WildMustang351's Avatar
Vehicle: 1970 Mustang Coupe
Send a message via Yahoo to WildMustang351
Sounds like a leak somewhere,All the gas is running back out of the fuel system while sitting.
Mine does the same thing,But then again mine sits for several months at a time without running.
Once it starts and runs for a while,It will start again later just fine.
__________________
WildMustang351 is offline   Reply With Quote
Old 07-28-2009, 11:36 AM   #6
photolabgirl77
2005 Ford Mustang
My Garage
The petal gets pumped at least 20 times and will still not start unless gas is poured into the carb.
Its the stock motor. I think the only thing changed a while back was an electronic start was added.
I know what the carb is and stuff but can anyone please give me a visual on the other things I need to look at? Like how to check if the choke is closed?
__________________
Old 07-28-2009, 11:01 PM   #7
tx65coupe
tx65coupe's Avatar
Vehicle: 1965 Ford Mustang
The choke is the flap on top. When the choke is engaged the flap should close off the top of the carb so less air gets in. When disengaged it should be opened up. If it is really hot where your at, then the choke may be making the car hard to start. You may not actually need it in hot weather even if the car hasn't been driven in a while.
Whats an electronic start? Do you mean electric choke?
tx65coupe is offline   Reply With Quote
Old 07-29-2009, 02:31 AM   #8
JMD
JMD's Avatar
Vehicle: 55 Lincoln
My son's Falcon with an I-6 was hard to start that way, turns out both his choke AND accelerator pump were inoperative....
We could close the choke by hand (Removing the air cleaner and actually closing the butterfly by hand) and it would fire...
No accelerator pump + choke valve loose on the shaft = 1 tough car to get started every morning....
Either one or the other working would probably get you by in FLA...
__________________
"In America it is YOUR RIGHT to be as STUPID as you wanna be!!
http://s245.photobucket.com/albums/g...CMS/39%20Ford/
http://s245.photobucket.com/albums/g.../66%20Mustang/
JMD is offline   Reply With Quote
Old 07-29-2009, 02:44 AM   #9
Canary94GT
1965 Ford Mustang
My Garage
Canary94GT's Avatar
That's how my truck was too! Both those parts were toast. It was such a PITA to start. The choke coil was so toast that it split and bent into 90 degree corners.
__________________
PSN: GreatWalrus
Videos
Old 07-29-2009, 03:47 AM   #10
Carlos Pineiro
Carlos Pineiro's Avatar
Vehicle: 1969 Mustang Grande (modified) Winter Blue Metallic
If you can't figure it out from the replies here (it could be a number different things), a mechanic can tell in short order if it is indeed a defective choke, a choke that isn't set right, a gas leak, a vacuum leak, or even a bad fuel pump after a quick inspection.
The best way to examine a choke is to start it with the engine ice cold. That might mean dropping it off at the shop the night before so it can be checked first thing in the morning. It may be a PITA to do that, but you will solve any choke issues for good that way and be done with it. Improperly set chokes will rob you of power, and can make your MPG skyrocket if you're running too rich.
If you don't have an electric choke, you might want to get one. It's the best way to go for effortless driving. Good luck PLG.
CP
__________________
Daily Drivers Rock.
Carlos Pineiro is offline   Reply With Quote
302, accelerator, bad, carb, carbed, engine, ford, gas, poured, pouring, pump, started, starts, symptoms, warm, weather
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
