Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-09-2009, 02:06 AM   #1
slo14
Vehicle: 65 ford mustang
Post matching numbers
i got a 65 mustang an my dad is buggin me on checking if the vin # match soo here it goes
engine block vin #
c60e-9425-b
eomoco is on the block
marked on water pump
c80e-d
the cars vin #
5r07a230949
slo14 is offline   Reply With Quote
Old 08-10-2009, 12:38 AM   #2
andrewmp6
Tell him matching numbers means the vin is on the engine which ford didn't do tell 68.On the earlier years its casting code which just means the parts are older then the cars build date.A little googling can give you guides how to decode all that.
andrewmp6 is offline   Reply With Quote
Old 08-10-2009, 06:01 AM   #3
remicks
remicks's Avatar
Vehicle: 67 Mustang
Like Andrew said you can't tell numbers matching on your 65. Ford didn't realize the future value of the documentation of what engine and trans go with each car and burned the records for the 64-66's. 67 is the first year that you can get a Marti report that will give you a detailed description of what came with your car.
The most you can get for your 65 is check out the date code on your block, trans, rear, fenders and most any other part of your car and hope that date code is earlier than your final build date for your car. The 64-66 were mass produced and what parts went into the car that could. So your engine could of been made 2 months before and your trans 4 months before. But there is no way to definitlively say that your car is numbers matching.
__________________
Drill until you hit those damn kangaroos.
Speed has never killed anyone. Suddenly becoming stationary... that's what gets you.
remicks is offline   Reply With Quote
Old 08-10-2009, 06:51 AM   #4
2+2GT
Vehicle: 66 Mustang 2+2GT
You have a 66 engine code, and a 68 water pump code. The only numbers you can match are the casting date codes on 64-67, if they are 1-8 weeks before the car build they might be original. The one exception is the K code, which had a partial VIN on the right front corner:
2+2GT is offline   Reply With Quote
Old 08-10-2009, 07:00 AM   #5
andrewmp6
If your door tag is still there decode it here http://www.mustangdecoder.com/plates_1965.html then you go from there and start matching stuff up.
Old 08-10-2009, 07:02 AM   #6
remicks
remicks's Avatar
Vehicle: 67 Mustang
nvm..
__________________
40, buy, c60e9425k, car, casting, classic, code, decode, ford, locations, matching, motor, mustang, numbers
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
