Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-11-2009, 10:33 PM   #1
ColoradoTom
Vehicle: 1969 Mustang Mach 1
Default Rookie Here with new 69 Mustang Mach 1 need help with Vin # location
Just bought a 1969 Mach 1 with a 351 Cleveland engine. The VIN # is not in the dash nor on the driver door. We know the driver door was replaced or fixed due to a deer hitting it. We have title from seller but know we will have to do a VIN # validation to get the car titled & tagged. Where else can we look for the VIN #?
ColoradoTom is offline   Reply With Quote
Old 08-11-2009, 11:38 PM   #2
4reboy
4reboy's Avatar
Vehicle: 1969 Mach1
The dash VIN might be folded underneath your dashpad.
I think the only last location of the VIN is on the engine bay wall where the fender bolts too. I believe it's on the driver side, you'll have to pull back the fender to see it.
And 1969 Mach 1's only came with 351 windsors, not clevelands. Just in case you didn't know that...
__________________
1969 Winter Blue Mach 1 M-code - mine
1969 Mach 1 428 R-code - dad's new project
1971 Mach 1 H-code - dad's (for sale)
Classic ROTM 2009 winner thanks everybody
4reboy is offline   Reply With Quote
Old 08-12-2009, 04:24 AM   #3
andrewmp6
Yeah pop the hood and on the right fender there is a cut out right there is the vin.Most states go by the vin under the hood the door tag is easy to change.Once you find the vin decode it here http://www.mustangdecoder.com/
andrewmp6 is offline   Reply With Quote
Old 08-12-2009, 02:08 PM   #4
Nabster
Nabster's Avatar
Quote:
Going to guess you don't have a 69... there isn't a vin under a cutout in the fender for us. We have to unbolt the fender and move it out of the way to see the vin there.
EDIT: Just went out to verify. Open the hood, stand on the drivers side. Count the bolts that are on the lip of the fender starting at the windshield, the VIN is stamped immediately to the left of the third bolt. I could see mine by undoing the couple bolts around it and just lifting up the fender. This picture is taken bent over peering under the gap, which is why it looks funny.
__________________
1969 Legend Lime Mustang
Nabster is offline   Reply With Quote
Old 08-14-2009, 03:11 AM   #5
andrewmp6
That's kinda dumb why did ford stop cutting the fender for the vin?
Old 08-14-2009, 03:36 AM   #6
Nabster
Nabster's Avatar
I agree. Probably stopped doing it because it saved a few pennies per fender. Tempting to make the cutout myself though, I don't really see a problem doing so either.
__________________
Old 08-14-2009, 04:54 AM   #7
Carlos Pineiro
Carlos Pineiro's Avatar
Vehicle: 1969 Mustang Grande (modified) Winter Blue Metallic
Quote:
Originally Posted by ColoradoTom View Post
Just bought a 1969 Mach 1 with a 351 Cleveland engine...We know the driver door was replaced or fixed due to a deer hitting it.
I've spent my entire life in a big city, so forgive my ignorance on this, but, a deer T-boned the car? Causing enough damage to have the driver's door replaced? Was he running at full speed?
CP
__________________
Daily Drivers Rock.
Carlos Pineiro is offline   Reply With Quote
Old 08-14-2009, 05:53 AM   #8
remicks
remicks's Avatar
Vehicle: 67 Mustang
Quote:
CP
Yeah I have seen it a few times before and its almost happened to me a couple times. They panic sometimes when they are on the side of the road or in the road when you drive by. When they panic they run across the street and sometimes right into the side of your vehicle. They can leave some good size damage. Depending their size they can more than easily total a car with a head on collision and more than dent body panels by running into the side.
__________________
Drill until you hit those damn kangaroos.
Speed has never killed anyone. Suddenly becoming stationary... that's what gets you.
remicks is offline   Reply With Quote
Old 08-14-2009, 03:23 PM   #9
69mach1377
1969 Ford Mustang
Everything about this car sounds suspicious...maybe the OP can clarify?
__________________
69Mach1-SteetBoss377 Clevor,351W blk/stroker crank,10:1cr,351C-2V hds,2500 stall FMX,3.50:1 posi,rack&pinion/tilt,17x8 Mach1 Rims(2003),all MSD,Holley750,custom paint,Shelby drop,Cam Adv
http://photobucket.com/albums/v618/danaranda
69mach1377 is offline   Reply With Quote
Old 08-14-2009, 09:34 PM   #10
Bravo
Vehicle: Future Mustang Owner
CP
Deer up my way grow to be well over 175lbs (Big bucks can get over 200lbs). I've seen them so serious damage by running into cars (easily enough to require a door to be replaced).
You'd be surprised at what kind of damage a 175-200lb mass running at 30mph can do.
Bravo is offline   Reply With Quote
1969, 351, 69, cleveland, code, codes, data, door, engine, fender, ford, location, mach, mustang, number, tag, vin
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
