70 Mach rear panel
Old 09-22-2009, 01:33 AM
Kdclem
Kdclem's Avatar
Default 70 Mach rear panel
Any ford body and fender guys out there. I'm pretty sure this needs pulled out. The picture shows the rear panel @ gas filler with a slight inward bend. Is this correct or should itbe pulled out?
thanks in advance
Kevin Clemens
[IMG][/IMG]
Kdclem is offline
Old 09-22-2009, 12:45 PM
boogerschnot
boogerschnot's Avatar
I couldnt see your pic because Im at work. but here is mine. Its got a slight curve to it, as its supposed to.
boogerschnot is offline
Old 09-23-2009, 02:13 AM
tx65coupe
tx65coupe's Avatar
I believe they are supposed to have a slight curve, like boogerschnot said.
tx65coupe is offline
Old 09-25-2009, 01:18 AM
Kdclem
Kdclem's Avatar
If you look closely at the picture, I know it's not a very good picture, but you can see a gap between the straight edge and the rear body panel. the gap I'm referring too is horizantal not vertical. I understand that Grande's and coupe's have a differnet rear panel than fastbacks and Mach 1, and that is where the confusion might be. This car is a Mach 1. The honeycomb body piece will attach to the rear panel, unlike Grandes and coupes. If someone has a 70 Mach and could post a picture that would be great. thank you
Kdclem is offline
Old 09-25-2009, 03:12 AM
tx65coupe
tx65coupe's Avatar
I'm not sure I understand what your saying about the gap being horizontal and not verticle.
If you mean that the center of the panel is bowed inward in the middle by the gas cap, then that is what I was thinking you meant. I believe that is normal for it to do that a little bit.
Old 09-25-2009, 04:13 AM
andrewmp6
andrewmp6's Avatar
They all do it bends in around the filler neck its normal.
andrewmp6 is offline
67LimeCoupe
09-30-2015 04:46 PM
Shawmp
09-18-2015 07:52 AM
09-16-2015 07:53 PM
TimeLord101
09-04-2015 09:27 AM
iamgobono
09-03-2015 12:37 PM
Quick Reply: 70 Mach rear panel
