Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-09-2009, 01:51 PM   #1
jrherald420
jrherald420's Avatar
Vehicle: 1968 Mustang 1995 Lincoln Mark 8
Default Need help with 460 block numbers.
I just recived a 460 block with the Mustang i just bought the other day. I decided to go to my storage unit today and check the block numbers and after some scraping i found D1VE-AA on the side of the block. After looking at a couple web sites i find the block numbers go back to 1968-70 and were used with the 429,429 CJ, and the 460 engines. Could anybody help me out???? Do i have a possable block that was used in 68-70 Shelby Mustangs???? What would this block be worth??
Heres the sites i found this info on.
http://fordifiedracing.homestead.com/460tech.html
http://raceabilene.com/kelly/hotrod/engine2.html
__________________
NEW CAR!! 1968 Mustang
1995 Lincoln Mark 8
1998 V6 Firebird
Opinions are like as*holes, and there's alot of as*holes on this site.
jrherald420 is offline   Reply With Quote
Old 10-09-2009, 05:55 PM   #2
03T1000
Vehicle: 2003 Terminator Vert 504 RWHP
First off, realize that your code read on the outside of the block is a enginerring revision number and DOES NOT neccesarily represent the production year. The actual production date is in the lifter valley. This is a common mistake that is made.
D0VE-A and the rare (as in... not all are thick webbed) D1VE-AA blocks have thick webs. These are prime candidates for the 4 bolt conversions such as the Blue Thunder splayed 4 bolt main caps.
The block you had/have was commonly placed into the 429 CJ config. Also note that even in the 2-bolt cap config and stock main bolts these blocks can handle everything under 800HP with no issues. There are some running 2-bolts with a good tune that have went past 1,000 HP with no block/main cap issues other than the expected main cap walk and fretting that comes over time at these power levels. Even a 4 bolt may get some amount of this artifact.
I "flexed" my Google-Foo for you and found this guy's nice little pictorial that shows the thick mains vs the thin mains:
Then scroll to the middle of this linked page and read this.... you are soon to be a 429/460 block GURU!
http://429mustangcougarinfo.50megs.com/components_3.htm
NOTE/CAUTION: THERE HAVE BEEN MULTIPLE CONFIRMED THIN WEB D1VE-6015-AA BLOCKS AS WELL, YOU MUST VERIFY THAT YOU HAVE THE THICK WEB BLOCK BY VISUALLY LOOKING FOR THE MACHINED DOWN WEBBING.
03T1000 is offline   Reply With Quote
Old 10-09-2009, 06:16 PM   #3
jrherald420
yeah i already found out all the info i needed a couple of hours ago. i have a 68-70 429/460 block. it looked like a thick web block intill i scrapped off the sludge and found the thin webbing of the block
__________________
1995 Lincoln Mark 8
1998 V6 Firebird
6015, aa, big, block, d1ve, dive6015aa, ford, numbers
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
