Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-15-2009, 08:17 PM   #1
gggelo
Vehicle: still in my dreams!
Default Your guys' thoughts?
So i bet all of you know about the mustang 2 suspension for the classic ol mustang.
improved steering, ride and etc. etc.
but to get it in there's quite the surgery. i mean cutting the shock towers and such and such.
but i happend to find this the other day..
http://www.fatmanfab.com/catalogpage.php?page=36
a tubular front end?! wow. why just cut up the shock towers? when you can just cut the whole front off!
so i'm just wondering what you guys think?
sidenote: this uses the macpherson suspension vs the mustang 2's (i think it's independent front suspension?) what do you think's better?
gggelo is offline   Reply With Quote
Old 10-15-2009, 08:33 PM   #2
Starfury
I'm not a fan of Mustang II suspension. Works great for small cars and hot rods, but it's not that fantastic of a design.
There's no real problem with a short arm/long arm suspension that's designed properly. The main problem with the stock Mustang suspension is that the geometry is screwy. It's based on the Falcon setup which is designed for ride comfort and freeway stability rather than handling. The Shelby/Arning UCA drop fixes the stock geometry by providing a better camber curve to keep the tires flatter on the road during cornering. Combined with a bigger sway bar, export brace, monte carlo bar, and good springs and shocks, you'll have an affordable suspension that handles great.
If you really want to go all out, something like the TCP or Global West tubular coilover setup goes a step further by moving the spring force to the lower control arm. This increases spring leverage, allowing you to run a softer spring without sacrificing handling ability. It also has a side effect of giving you an adjustable ride height in some cases.
If you're after room, Crites offers a shock tower notch kit to allow you to drop that cleve into your '65.
A complete tubular front end is way overkill on most cars. With a terminator or 512 crate motor swap, I suppose I can see it. But that's a lot of time, effort, and money.
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Old 10-15-2009, 10:05 PM   #3
gggelo
so what your saying is that the mustang 2's suspension is good but compared to what you can do with the stock suspension by improving it, it's not that great?
also if you were to put a mustang 2 suspension and cut off the shock towers, you can't put the export brace or the monte carlo bar right? wouldn't that cause flexing in the body?
Old 10-15-2009, 10:22 PM   #4
Starfury
I just don't see the point in doing all that work for such a plain jane suspension setup. There are better ways to get things done.
You could still use a monte carlo bar, but you'd have to fab up some sort of inner fender-to-cowl bracing.
__________________
Tad H.
'67 Fastback
331 stroker
Old 10-17-2009, 04:51 PM   #5
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
I don't see the logic of hacking up a classic car that bad, period. Regardless of the benefit. Everytime I see one that someone has done that to at a car show or in a magazine it makes me cringe.
hiboostwoody is offline   Reply With Quote
Old 10-18-2009, 10:21 AM   #6
tx65coupe
tx65coupe's Avatar
Vehicle: 1965 Ford Mustang
I agree, I wouldn't cut my car up for that. No way!
tx65coupe is offline   Reply With Quote
Old 10-18-2009, 03:43 PM   #7
THUMPIN455
THUMPIN455's Avatar
Vehicle: Too many to list, 30+
MII is nice for street rods that arent expected to do much other than look cool and be comfortable for the gray haired guy driving it. They work ok in drag cars because they are relatively light, but they arent a corner carver. If I wanted to make either the Cougar or the PoD corner well, I would go with the coil over setup that moves the spring to the lower control arm. There is also an IRS that bolts in the rear and they make a big difference in handling, but arent too great for the drags. Not horrible but not great.
Some people change things just to change things and it doesnt matter to them if its better than it was before as long as its different. I would rather improve something if I am going to the effort to change stuff, especially on the scale you are talking about with the entire front end. If I was considering the entire fromt clip out of tubular, I would just go the full monty and tube the entire car and build a suspension that isnt hampered by anything stock. That would be big $$$ though...
__________________
POD and Cougar progress pics:
71 Pit of Despair Mustang
67 Cougar
THUMPIN455 is offline   Reply With Quote
Old 10-18-2009, 06:13 PM   #8
gggelo
okok i get i get it. you won't operate on your pride and joy.
but let's say you were just starting a project and you got a car whose front end was obiliterated.
considering the "perks" of having an updated "structure" and etc.
would it be feasible?
i mean you don't notice it until you pop the hood right?
Old 10-18-2009, 06:17 PM   #9
gggelo
tube the entire car eh? hm... how would one approach that?
Old 10-18-2009, 11:05 PM   #10
hiboostwoody
I guess it would depend on how "rare" the car is. If it's just your average no frills C-code or I6 car, I MIGHT consider it. BUT, if it was something like a Boss car or other rarity, I wouldn't.
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
