Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-30-2009, 12:26 AM   #1
photoguy_43420
Vehicle: 73 ford Mustang Mach 1
Default 73 Mach 1 with Motor Problems
I have a 73 Mach 1 with a 351c in it. It will run about half a block and want to die you can pump it and it will try to run but then dies. It will then start right up. If the motor is not under load you can rev it right up and it will not miss a beat. It just when its under load when the problem happens. Today I drove it around the block twice and at the same spot it just died. I have put a new fuel pump and filter and have checked the coil. It is pumping all kinds of fuel. Any ideas what to check next?
Thanks,
Guy
photoguy_43420 is offline   Reply With Quote
Old 10-30-2009, 12:32 AM   #2
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
Sounds like you might have a float level that is way too low causing you to run out of fuel. It runs at idle and without a load on it because the demand for fuel isn't as high and the low float setting can keep up with it but when you put a load on it the demand for fuel goes up and it can't keep up with it anymore.
__________________
Absolute rule number one: If it has tires or tits, your going to have trouble with it.
hiboostwoody is offline   Reply With Quote
Old 10-30-2009, 12:41 PM   #3
photoguy_43420
I will give that a look. Strage thing about is the carb has not been taken apart in a long time. The car ran great until this happened late this summer. I got to think its a fuel problem too.
Thanks,
Guy
Old 10-30-2009, 06:39 PM   #4
hiboostwoody
If it has the brass float in the carburetor it could have started getting fuel inside it causing it to not float anymore. Very common.
__________________
73, beat, mach, sale
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
