Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-31-2009, 05:25 PM   #1
1969macher
Vehicle: 1969 Ford Mustang Mach 1
Default 1969 Mustang Dash Guages Problem
Just finishing up the restoration process and thought everything was finally good. Started up the car and the fuel gauge, temp gauge, were both pegged at max. The oil guage was also not acting normal. Any suggestions of what might be wrong?
Thanks,
Barry
1969macher is offline   Reply With Quote
Old 10-31-2009, 06:04 PM   #2
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
Sounds like you have a short. They all work on resistance that is relayed to them by the senders. If you have the sender wire grounded, it will peg the gauge. Check to make sure you didn't pinch or run a screw through any of the wiring.
__________________
Absolute rule number one: If it has tires or tits, your going to have trouble with it.
hiboostwoody is online now   Reply With Quote
Old 11-01-2009, 12:11 AM   #3
Stepman
Vehicle: 69 coupe
Sounds like aa typical bad IVR. The regulator that controls the guages. It should have 12v going in but a pulsed 5v coming out. I would check or replace that.
Stepman is offline   Reply With Quote
Old 11-01-2009, 01:22 AM   #4
hiboostwoody
I thought about the IVR but, not being familiar with the '69 gauge panel, I wasn't sure if it had one.
__________________
Old 11-01-2009, 10:12 PM   #5
chillininnh
Send a message via Yahoo to chillininnh
Try this bro.
http://1970mgr.org/_GaugesQuit.htm
__________________
69 Mach 1 H-code Restomod 418W/TKO600/RMP Front Coil-Over/TCP Manual R&P/FR Tilt Column/GW Subs/GW Lowering Leafs/GW Del-A-Lum/Factory Power Front Brakes/3.70 9" Auburn Diff/Painless Wiring
Project Pics
http://s63.photobucket.com/albums/h127/chillininnh/
chillininnh is offline   Reply With Quote
1969, 69, dash, fuel, gas, gauge, mustang, panel, pics, wiring, working
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
