Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-07-2009, 12:13 PM   #1
66200coupe
Vehicle: 1966 ford mustang coupe
Default Noisy 66 200ci
Hi Guys,
My 66 200 makes what appears to be value or lifter noise at higher RPMs. I adjusted the rocker arm per specs but noise is still there. Any suggestions?
Thanks,
Tom
66200coupe is offline   Reply With Quote
Old 11-08-2009, 08:21 AM   #2
JDraper
JDraper's Avatar
Vehicle: 1966 Coupe, 2004 Mach 1
Could be the valves floating a little because of weak valve springs or the lifters bleeding off a little. Do you notice a power drop at the same time the noise occurs?
__________________
'66 Coupe, '04 Mach 1, '05 F-150 SCrew, '08 Focus
JDraper is offline   Reply With Quote
Old 11-08-2009, 04:42 PM   #3
66200coupe
Yeah, the noise gets louder at higher RPMs and the power drops. I did replace the lifters recently so maybe I should test/replace the springs?
Thanks,
Tom
Old 11-14-2009, 07:38 PM   #4
66200coupe
Default Noisy 6cly
I'm back at it. I bought new springs and when I took off the old ones I found out that the old spings were taller than the new ones but the new ones are the right size per specs. How will shorter springs effect the performance/noise?
Thanks,
Tom
Old 11-15-2009, 08:40 AM   #5
JDraper
JDraper's Avatar
It's not necessarily the spring length, but the spring rate and how fast the spring responds to change. Put 'em in, set the pre-load on the lifters properly and see what happens.
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
