Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-08-2009, 09:41 PM   #1
Cur1ousG
Vehicle: 1967 Mustang Coupe
Default Is soda blasting the best media to use?
My body and frame look to have little rust so I thought soda would be a good choice (as it works on paint and not rust). I figured I could use something else to take care of the rust after the blasting was done.
However I've heard these cons against soda:
(1) gets everywhere and very/very hard to clean out of car
(2) Causes major issues with primers and paints post-blasting as the primers and paint won't stick to soda blasted metal due to film the process leaves?
So my questoin is in your opinion what is the best media to use when blasting a car that "seems" to have very little rust (and if you can list the cons for the choice you list, as we all know there isn't a perfect solution out there)
Cur1ousG is offline   Reply With Quote
Old 11-09-2009, 01:10 AM   #2
THUMPIN455
THUMPIN455's Avatar
Vehicle: Too many to list, 30+
Sand it down with a DA and 80 grit. You can also sand it down after being soda blasted so the primer will stick a bit better. You have to rough the surface a bit to give the primer something to bite into.
__________________
POD and Cougar progress pics:
71 Pit of Despair Mustang
67 Cougar
THUMPIN455 is offline   Reply With Quote
Old 11-09-2009, 01:11 AM   #3
hiboostwoody
hiboostwoody's Avatar
Vehicle: 1967 Fastback
Yes, it is very hard to get cleaned out and yes, it does leave a film. The way to get rid of the film is to pressure wash the car with a solution of vinegar and water to neutralize the soda film. As for cleaning it out, good luck. Maybe an air blower and a shop vac?
__________________
Absolute rule number one: If it has tires or tits, your going to have trouble with it.
hiboostwoody is online now   Reply With Quote
Old 11-09-2009, 02:30 AM   #4
4reboy
4reboy's Avatar
Vehicle: 1969 Mach1
I had my car media blasted, I forget which sand was used though. It was great, took out all the rust, all the filler, primer, and layers of paint. There is still some sand in a few places of the car I'm sure but if the whole car is stripped then it shouldn't be a problem.
People seem to hype up soda blasting way too much. From what I know the material is very expensive and it takes much longer to soda blast a car than to give it a typical media blast. Sure, it is a lot softer on the car (hence why it doesn't take away rust), but if the person knows what they are doing there is no problems associated with "sandblasting." Both me and another member on here had our cars sandblasted at the same place (at the same time) and there was no issues associated with it, the whole car was roughly 500 bucks or so if I remember right.
I also sandblasted my engine bay myself a year or so early to having the whole car done, no issues there and it created a nice surface for paint adhesion, and now it still looks great three years later.
__________________
1969 Winter Blue Mach 1 M-code - mine
1969 Mach 1 428 R-code - dad's new project
1971 Mach 1 H-code - dad's (for sale)
Classic ROTM 2009 winner thanks everybody
4reboy is offline   Reply With Quote
Old 11-15-2009, 09:13 AM   #5
JDraper
JDraper's Avatar
Vehicle: 1966 Coupe, 2004 Mach 1
Walnut shell blasting is another way to do. Easier to clean up and more environmentally friendly. Works very well.
__________________
'66 Coupe, '04 Mach 1, '05 F-150 SCrew, '08 Focus
JDraper is offline   Reply With Quote
blast, forum, mustang, soda
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
