Go Back   MustangForums.com > Ford Mustang Tech > Classic Mustangs > Classic Mustang General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-08-2009, 10:21 PM   #1
dhg
Vehicle: 1966,ford,mustang
Default install help, clutch spring
I'm new and would appreciate some help. My car is a 1966, 3spd, 6 cyl. I need to install the under the dash clutch spring. Could someone help me with tips on doing this. Thanks- DHG
dhg is offline   Reply With Quote
Old 11-08-2009, 11:45 PM   #2
rmodel65
2nd Amendment Gear Member
rmodel65's Avatar
Vehicle: 1965, ford, mustang fastback
Send a message via AIM to rmodel65 Send a message via MSN to rmodel65 Send a message via Yahoo to rmodel65
its pretty stiff you actually dont even need it.....
i guess take some vise grips and grab hold and lock em down so tyou have some leverage
__________________
Founder Rmodel's Mustang Militia
“If ye love wealth better than liberty, the tranquillity of servitude than the animating contest of freedom, — go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that ye were our countrymen!”
~Samuel Adams
rmodel65 is offline   Reply With Quote
Old 11-08-2009, 11:57 PM   #3
tx65coupe
tx65coupe's Avatar
Vehicle: 1965 Ford Mustang
That can be a royal pain in the rear. I remember messing with that a couple times. It is stiff. I would use vise grips or something that you can hook through it maybe.
tx65coupe is offline   Reply With Quote
Old 11-09-2009, 12:19 AM   #4
Starfury
First, are you using a stock replacement long-style clutch, the type with 3 fingers in the middle? Or are you using a modern diaphragm-style clutch, with a bunch of fingers in the middle? If you're using the latter, leave the spring out.
If you need to reinstall the spring, disconnect the linkage, push the pedal down, remove the pedal stop bushing, and pull the pedal back up. You should be able to work the spring onto the pedal. Once it's reinstalled, push the pedal down and replace the stop bushing. Pull it back up and reconnect the linkage.
__________________
Tad H.
'67 Fastback
331 stroker
Starfury is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
