Engine cranks no fire
Old 12-01-2009, 12:10 PM
midtown mobile
midtown mobile's Avatar
Question Engine cranks no fire
Help I am trying to start up a 1966 Mustang Coupe, 289, 2bbl carb thats been sitting. Here's what ive done so far; drained the old (yellow) gas, flushed the lines, replaced, condensor, pointset (gap at .32 cause specs say .30 to .33) spark plugs, coil, starter solenoid, new battery, distributor cap & rotor, spark plug wires new leads on coil to dist and wiring from dashboard (ignition key) to coil. Have tested the + terminal to engine block for continuity and its good. Key off-nothing, key on-get signal. But no spark from coil to distributor, its a brand new coil and i even tested it for resistance.
Engine cranks just fine but it wont start. Where is my electrical break?
midtown mobile is offline
Old 12-01-2009, 04:09 PM
urban_cowboy
urban_cowboy's Avatar
Welcome to the forum. This is the general section, so you should probably post this in the technical classic section. A bunch more help will come from there. I would get a wiring diagram for the mustang and check that out. There used some links to wiring diagrams in the FAQ section.
To get you started, with a point type ignition the positive pole of the coil should be connected to the ignition solenoid (i or ignition terminal). This post will have full voltage while cranking (12v) and resistance voltage (9v) when running. The negative pole of the coil should be connected to the distributor (points breaker) and should ground out only when the distributor is requesting spark come out the high voltage side of the coil. Otherwise it is open. Think of the - as being a trigger.
If you have good voltage to the + post and have a good connection from the - post to the dizzy points, and you still are not getting spark out of the coil, the problem is probably in your dizzy.
Hope this helps.
urban_cowboy is offline
Old 12-02-2009, 05:59 PM
Stepman
Stepman's Avatar
I would look at the points gap. With the dist cap off, crank the motor and make sure that they open and close. I set them up to almost contact the "flat" of the dist cam, then bump the motor to make sure they open. If you can find a dwell meter to set them, it'll be more accurate than "gapping" them.
Stepman is offline
Old 12-05-2009, 11:34 AM
midtown mobile
Question reply to cranks but no fire
Thanks for that will try it but ah, ya lost me on the 'dizzy points'. . .
Old 12-05-2009, 11:36 AM
midtown mobile
thanks stepman, im a nuts and bolts guy, electrical is ,,, chinese algebra to me.
Old 12-05-2009, 11:37 AM
midtown mobile
Hope this helps.
PS - im digging the mustang, nice color. What she running? Stock 427-429?
Old 12-05-2009, 11:05 PM
hiboostwoody
hiboostwoody's Avatar
Dizzy is slang for distributor.
hiboostwoody is offline
Old 12-07-2009, 11:23 AM
urban_cowboy
Thank you. No need for a big block to break parts. It was originally a 351W car, but now has a Dart Block 383@ stroker making about 475ft*lbs @ 4000 and 440hp @ 6000. With a any more torque, I would have to custom build a drive line and probably build a tube chassis to support it.
Nick Oliver
10-17-2018 04:22 AM
StalkerGT
09-25-2015 02:41 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Engine cranks no fire
