Hood shaker on a 65?
Frey Mustang
I can't seem to post Pic's on this subject, But I put one on the 66 Coupe - lots of work, looks factory, willing to share pics over Email rikfrey@comcast.net
I was in the 2012 Portland roadster show...
Hey buckeye, that really doesn't look that bad. one question, how did you get from the initial cut in the hood showing the two rear braces sectioned, to a prep'd hood where the radius is two inches inside that initial cut? I also see you filled your cowl, good job! How's the air circulation with the cowl filled, and the windows up? Thinkin of doing the same.
RIKFrey here - yeah a few details to cover I guess..
After cutting the hole in the hood I had to (carefully) cut out both lower braces. Take out about a 2" section weld the hood braces back together and them reweld the braces back to the hood in the new location. It was 1/2 a day in metal work. the other 1/2 day was spend fabricating the trim ring from flat steel using a stretcher/shrinker. I have a few more hour in the hood as many of the underside vent holes were sealed up -and I took time to wet sand it donw to 300 grit.
As for the cowl being sealed up - I loose the lower vent air into the car. But I either run with the (power) windows down or the AC turned on and the windows up. I've had a little fogging on the front window, but just running recirculated air clears that up. But I[ve only see that once or twice ona cold morning when I first get out onthe road.
One question not frequently asked is air intake. I'm running a 408W, 1200 CFI throttle body, AFR205 heads, headers, 3" exhaust, fuel injection. 464 RWHP and 422 TQ the dyno looks like 45 degree line from 0-6000 RPM. We dyno'd the car with the shaker on and shaker off - dyno numbers were the same.
I'm just a hobbiest - so doing this work is mostly time and some metal fab skills. The average dude could tackle this project, ut I have to admit. I DO turn a few heads going down the hi-way...
Oh and BTW thx for posting the pic's I can always be reached at RIKFrey@Comcast.net (Located in Beaverton, OR USA)
