Front end toooooo low
Jonk67, the unloaded-height of the spring means very little all by itself. If you'll notice, the wire diameter of the 560# is thicker, and the coils are closer together...
Bottom-line, it's a stiffer spring, that has far less travel engineered into it than the stock spring. The LOADED height is most-likely not that much lower because your original springs were likely CLAPPED-OUT to begin with. You're not going to realize the full 1" drop, when your tired original springs are already sagging lower than they sat when new. When springs advertise a specified "drop", that measurement is taken from stock ride-height, not 45-year-old worn-out ride height. That's why it is common for people to install lowering springs and say "my car didn't go any lower". Using your old springs as the benchmark is the flawed logic in the equation.
Hope this helps!!
Rick
NPD
Hope this helps!!
Rick
NPD
In the realm of O.E. application springs, it's more complicated (check the Eaton charts), but suffice it to say that 65-66 coils don't cross-over to 67-up.
I emailed Dan from Glazier Nolan and sent him before and after pics. I purchased the same performance kit from them for my 66 and lost no height at all, in fact I may have gained a little. I didn't do the Shelby drop on that install.
The difference between the before and after is immense and not what I was looking for. I was looking to drop the front, but not this much.
BEFORE
AFTER
BEFORE
AFTER
No. In the realm of aftermarket performance/lowering springs, typically 65-66 is one part #, and 67-70 is another.
I am getting frustrated. I emailed Dan last night and his reply was that these springs were stock replacements. That's fine, but I had ordered HD Springs, whatever that means, from their performance handling package. They are not drop springs, at least not according to him in his reply. I am just stumped.
What springs do I have in there??? That's all I want to know and then go from there.
I never mentioned that when I picked up the rear leaf springs I got the last pair and when I went to install them they were in fact Cougar springs. I had to drive back up to exchange them. That was a 5 hour round trip and to Dan's credit he offered parts equal to the tank of gas it cost.
Sorry for the rant. It's not my intention to bash G/N, I am just frustrated. I ordered a Hi-Po engine pivot and received the standard one just the other day. $9 in shipping for a $15 part.
problem here is that the car is very low in the front unsettled. in all cases i came across the front lowers another good bit after a short drive, which easily can become too low
but why don't you post in the technical thread. i think most of us forget about this general jibba jabba section. only saw the thread today
