If your keeping the car a inline 6 that will work or have a machine shop redrill the axles to 5 lug.If the car is going to be a v8 you need a 8 inch rear end.
from the reseach i have done, you do not have to have an 8 inch rear for a V8.
But i rather put in a 8 inch vs all the work to get a 5 lug 7.5.
I think that is the main point to take from this discussion. A used 8" in good shape can be had for a couple hundred bucks (probably less?). I imagine you'd spend at least that much with a machine shop trying to modify the existing axles, then find backing plates and drums (which you may have to do in any case).
