Can you repaint the interior rear quarter panels?
Old 08-07-2011, 11:21 AM
68GT 302
68GT 302's Avatar
Default Can you repaint the interior rear quarter panels?
I am working on my 68 coupe and one of the things I need to fix is the interior rear quarter panels. They aren't in terrible shape, but they are peeling / possibly rusting in the corners by the rear windows. I was curious if anyone has had any luck repainting these or if it is something that you typically just replace?
The paint has also rubbed off on my door panels where you would rest your arm with the window down and I wouldn't mind repainting that as well.... again, if it can be done.
If it can be done, where do you go to get good matching paint? I have parchment colored interior on my car.
68GT 302 is offline
Old 08-07-2011, 12:41 PM
HGC
HGC's Avatar
I did both. I actually just used undercoating on the interior quarters. You can do the top of the dooor by scuffing it up with Scotchbrite. Don't use sandpaper. You'll sand off the texture in the metal. Then shoot it with a spray can of interior touch up paint.
HGC is offline
Old 08-07-2011, 12:42 PM
HGC
HGC's Avatar
Oh yeah, paint all of the metal on the door. Not just the top. It will look better.
HGC is offline
Old 08-07-2011, 12:44 PM
HGC
HGC's Avatar
And while you're at it, open the door and lay down and look up at the bottom. Rust area for Mustangs. As long as it did not eat through the metal just sand it, prime and paint with exterior touch up.
HGC is offline
Old 08-07-2011, 12:50 PM
68GT 302
68GT 302's Avatar
Thanks for the tip. Was that pretty close to the original color on your door or did you go with something different?
68GT 302 is offline
Old 08-07-2011, 01:04 PM
HGC
HGC's Avatar
It was an exact match. This brand is pretty good. The spray nozzle on the can actually sprays a vertical pattern instead of the usual scatter pattern so you get much better results. It is fairly thin paint so be careful of runs. I did that about three years ago and it is doing fine. I probably bought that from NPD or California Mustang or John's Mustang. You can probably get the same brand from a number of suppliers.
HGC is offline
Old 08-09-2011, 08:26 AM
68GT 302
68GT 302's Avatar
On the quarterpanels I have some rusting / flaking in the corners by the windshield. Should I sand those parts down to get rid of the rust or treat it with a rustoleum type product prior to painting?
68GT 302 is offline
Galactic
04-29-2019 02:56 PM
McLeary
03-14-2016 07:50 PM
11-10-2015 11:39 AM
Gkid182
09-22-2015 08:17 AM
v8sn95
09-07-2015 10:17 AM
Quick Reply: Can you repaint the interior rear quarter panels?
