sway bar's and subframe connectors
Old 09-29-2011, 06:19 PM
topher_csr
topher_csr's Avatar
Default sway bar's and subframe connectors
I am looking to do a few things to my 1965 this winter, and i was wondering how big of a difference bigger sway bars, and sub frame connectors will make. mustang depot has a kit with a bigger front and rear sway bars, and sub frame connector. does anyone have this done on their car? and was it a noticible difference?
topher_csr is offline
Old 09-30-2011, 01:44 AM
andrewmp6
andrewmp6's Avatar
To me sub frame connectors are a must on any uni body car it will take a lot of flex out of it.The ones that look factory are http://www.tinmanfabrication.com/ind...=cat/cat60.htm
andrewmp6 is offline
Old 10-05-2011, 03:53 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
+1 on the subframe connectors. Do your car a favor and get some.
fastbackford351 is offline
Old 10-05-2011, 04:51 PM
Coupe
Coupe's Avatar
I am going to be on the other end of the spectrum here.
Subframe connectors on a 65 car can help, but if your floor is flexible due to floor pan patches and overlapping panels, or worse then I recommend making the car right first.
If the floors are proper you may want to look at adding front torque boxes on both sides. They connect the front frame rails to the outer rockers, and those are both thicker and stronger metal than those front floor pan extensions, and it makes for a wider frame. They were in the ragtops from the start, but In 68 Ford put torque boxes on both sides of the hard top cars, and it was more money to do that than it would have been to just add a tube that we call subframe connectors these days.
Store bought SFC's only mount to the front floor pan support extensions, and those things do not have any real strength to them. If you can remove those and connect to the front frame rail then you may be on to something.
Just my .02
Coupe is offline
Old 10-05-2011, 05:15 PM
LynnBob Mustang
LynnBob Mustang's Avatar
SFC's are great. They will also give more jacking locations to jack the car up.
You will be fine with the SFC's that go from the front frame rails to the rear frame rails, most of them go there anyway, are better then nothing, and will improve the car a lot!
Lynn
LynnBob Mustang is offline
Old 10-05-2011, 07:23 PM
scootchu
scootchu's Avatar
I put sub frame connectors on my 66 coupe and it made a world of difference.
scootchu is offline
Old 10-05-2011, 09:07 PM
fastbackford351
Foghorn Leghorn
Torque boxes would be nice too but when I put my sfc on the whole car tightened right up. If my fastback had had sfc's from the get go I'll bet the roof never would have oil canned.
jwog666
12-27-2021 08:09 PM
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
fastbackford351
10-01-2015 12:24 PM
winner99
10-01-2015 10:52 AM
Quick Reply: sway bar's and subframe connectors
