Is it a Cobra Jet engine?
Old 11-04-2011, 05:28 PM
Detector
Detector's Avatar
Default Is it a Cobra Jet engine?
Trying to tell if this is the original CJ in my Q code 73 Mach 1. Eyeballing looks to be a least a Cleveland. Has the 4 cast in the head upper corner and the water jacket for the heater hose is built into the block not the manifold. What do you think?
Staggered valves.
Not sure what this cast number is in the head. Date the head was cast maybe?
The 4 cast in the head near intake indicating V4.
Heater hose/thermostat in the block.
Detector is offline
Old 11-05-2011, 01:32 AM
andrewmp6
andrewmp6's Avatar
Look for the block code its under the starter that will tell you what the block is.The 4 on the head just means 4v or 4 barrel.
andrewmp6 is offline
Old 11-05-2011, 06:28 AM
Detector
Detector's Avatar
I'm going to replace the starter today so I'll see if I can get the cast numbers.
Detector is offline
Old 11-05-2011, 10:13 AM
Detector
Detector's Avatar
Looks like D0AE-L with a cast date of 0E22
Detector is offline
Old 11-05-2011, 06:53 PM
Detector
Detector's Avatar
Well here is the numbers I found on the back of my engine on the drivers side block. Can't really make sense of it.
Detector is offline
Old 11-06-2011, 09:52 AM
GT350R Klone
GT350R Klone's Avatar
You have a standard 70/71 351C, with a two bolt main.
The CJ would be D2AE-CA and have a four bolt main.
GT350R Klone is offline
Old 11-07-2011, 12:11 PM
Detector
Detector's Avatar
Notes on 351C Block Casting Numbers
Be careful what you read on the internet. Boss 351s were produced with at least two different casting numbers, one of which is shared with 2-bolt main, non-Boss 351C engines of the era - casting number is DOAE-L. For the Boss 351, Ford drilled this 2-bolt block to accept 4-bolt main caps. Most DOAE-L blocks have 2-bolt main caps. For the 351-4V CJ engine, many websites will tell you that the block casting number is D2AE-CA. Indeed, every 351C-CJ I've seen used the D2AE-CA block, but I've also seen this same block in 2V 351C Torino station wagons, with 2 bolts on all five caps. Again, it's a case of Ford selectively drilling blocks to accept 4-bolt main caps. So if you find a D2AE-CA engine, remove the oil pan and inspect the main caps before purchasing it.
I find a lot of different information all over the Internet LOL.
Detector is offline
Old 11-07-2011, 11:31 PM
GT350R Klone
I think the statement above is consistent with what I said.
D0AE-L = standard 351C
D2AE-CA and have a four bolt main = CJ
Old 11-07-2011, 11:41 PM
andrewmp6
andrewmp6's Avatar
Or drop the oil pan see if its 2 bolt or 4 bolt mains.
Old 11-08-2011, 04:07 AM
Detector
Detector's Avatar
Agreed. I just thought it was interesting that it says the Boss 351 also could have that casting number.
Form the Boss 351 Registry:
Boss 351 block cast numbers
Cylinder Block:
Ford part Number
D1ZZ-6009-D
Block stamped number
DOAE-L
The Earliest Date code you will find a for a stock engine would be April 1970 that would be" D "
All boss blocks that were installed in cars were DOAE the nest casting was D2ae this is one year after the cars were built . No boss 351 had screw in freeze plugs and the two bolt blocks were no weeker than the boss blocks . We were told for a matching numbers block it needed to be with in 6 weeks of the build date of the car. The D1ZE-a or D1ZE-B was a part number stamped into the blocks a long with the build date. some people confuse this with the casting number.
Picture of the block cast numbers on a 71 R code Boss 351
Detector is offline
Quick Reply: Is it a Cobra Jet engine?
