Pop Pop Poppin!
Old 04-23-2012, 08:54 PM
Toastintx
Toastintx's Avatar
Default Pop Pop Poppin!
ok guys another ? just got my 65 running. i have new suspension all around. still oem type. but new tie rods upper lower the works. my question is that its making a loud popping noise when moving. will this settle in or is something wrong
Toastintx is offline
Old 04-24-2012, 09:49 PM
GT350R Klone
GT350R Klone's Avatar
Yea, you should not hear a popping noise. I would make sure everything is in place and tight.
GT350R Klone is offline
Old 04-24-2012, 10:40 PM
russellthelovemuscle
russellthelovemuscle's Avatar
i have the same issure with my 2000 gt after i installed a upr k-member kit. two problems i have is after i lower my car from being jacked up the coil over spring doesn't like to set in place and makes a ton of horiable popping noises until i jack back up and re-set. another is my sway bar in the front doesn't allow me to tighten the bold from the control arm and makes a clear solid pop when i go over bumps. i plan on fixing that with a bump steer kit
russellthelovemuscle is offline
Old 04-25-2012, 01:19 AM
andrewmp6
andrewmp6's Avatar
Is the sound coming from the front end of your car?When does it make these sounds is it only over bumps or turning left or right?
andrewmp6 is offline
Old 04-25-2012, 06:23 AM
Toastintx
Toastintx's Avatar
yeah mp6 its the front i notice it the most going slow. it doesnt matter turning or not it pops. when i jack up the front end it makes a poping sound also, i guess i'll get under there this weekend and make sure everything is tight. thanks guys
Old 04-25-2012, 10:14 PM
andrewmp6
andrewmp6's Avatar
I would check every bolt see if its tight and lube everything if that don't fix it then its gonna get fun.
cr620
10-03-2022 10:18 PM
MacSerio
09-27-2015 01:05 PM
humpbackshooter
09-24-2015 10:07 AM
gagemcc
09-22-2015 09:43 AM
Sminemann
09-17-2015 09:24 AM
Quick Reply: Pop Pop Poppin!
