Starter solenoid
Old 04-29-2012, 10:47 AM
lucasp
lucasp's Avatar
Default Starter solenoid
Is there any way of completely getting rid of the solenoid?
Thanks,
lucasp is offline
Old 04-29-2012, 11:17 AM
03gt04mach1
03gt04mach1's Avatar
Thanks,
Seriously? You need it to disengage the starter after cranking.
03gt04mach1 is offline
Old 04-29-2012, 12:48 PM
lucasp
lucasp's Avatar
There got to be a way somehow. Doesn't the key disengages it after you start it? Help me out if I am wrong.
Thanks,
lucasp is offline
Old 04-30-2012, 07:43 AM
03gt04mach1
Thanks,
During cranking you turn the key ALL the way to engage the Starter from the Solenoid. When the engine starts, you let go of the key and it springs back to the run setting in the ignition switch and cuts Starter motor current at the Solenoid, so the Starter doesn't keep turning and tearing up the Flywheel and the Starter gear. If you want to by-pass the solenoid, you'll have to hide a manual switch under the dash that's well hidden. That way you can start it without the key, but so can anybody else. That's why you have to have a good hiding spot, depending how you by-pass the Starter Solenoid. I wouldn't want to do it myself, with the timing involved, cutting the by-pass switch in time without grinding the Flywheel and Starter Gear, or both. I'd stick with the Solenoid. I hope this helped.
Old 04-30-2012, 08:22 AM
JMD
JMD's Avatar
You can eliminate the fender mounted solenoid in favor of a starter mounted solenoid by using starter from a 90s Mustang. (from a 351 Mustang for sure).
I prefer the fender mount solenoid myself, it is easier to deal with when it breaks, and it makes for a handy junction point for hot wires.
EDIT; Oops... I-6, I don't know if you can get a starter with a solenoid on it for the 6 or not...
JMD is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
logan409
09-26-2015 07:43 PM
jaiidutch
09-14-2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
daytooday
09-01-2015 09:33 AM
Quick Reply: Starter solenoid
