Need advice for a compressor
Old 07-18-2012, 11:54 AM
  #21
Couper
Couper's Avatar
Originally Posted by TexasAxMan
Thanks for all the input guys!
I ended up buying the SpeedAire in one of the craigslist ads Coupe posted. Brand new 5 HP motor, freshly cleaned and lubed pump, great shape. It also came with Graco drier, regulator and oiler. I paid $700. How'd I do?
I've got to plumb this together and get it wired up. I'll be using DA sanders in the near future, so I guess the oiler is a good thing. I'm not sure how to cut it off for painting though, and I'm pretty sure oil and paint don't make a pretty color. Anyone got any clues?
As far as care and feeding, do I just drain the condensate periodically, or is there more to do?
Thanks again for all the input!!
Hows that comp what size and is it big enuf, buy it again?.
Couper is offline
Old 05-24-2013, 12:32 PM
  #22
Couper
Couper's Avatar
Size:  66.9 KB[/QUOTE]
Mr V what filter, reg., sep set up are you running?
Couper is offline
Old 05-24-2013, 12:43 PM
  #23
Couper
Couper's Avatar
Picked up this baby last week off CL for $500
Looking for some info / guidelines on filter / reg / seperator set ups,....
From the discharge I'll have flex tube to hard pipe
particle filter
as far up to the ceiling as possible
drain leg at the bottom
across garage and back with 1/2" pipe geting 50 ft horizontal before first drop
2" drop per 25 ft
feeding from the top of the run for the drop
drain leg below the vertical rise into filter / sep / final regulator
Couper is offline
fastbackford351
10-01-2015 12:24 PM
Shadow7874
09-24-2015 09:06 PM
EASTIDEE123
09-15-2015 11:08 AM
fastbackford351
09-12-2015 09:42 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Need advice for a compressor
