DynaMat (or similar product) + OEM insulation? Or just one?
Old 06-04-2012, 02:14 PM
shelbymustangdan
shelbymustangdan's Avatar
Default DynaMat (or similar product) + OEM insulation? Or just one?
Are products like Dynamat (or similar products) meant to be used in addition to the stock OEM insulation on the firewall and floors? Or is it meant to be a stand alone product without using the OEM insulation?
Thoughts? Experieces??
shelbymustangdan is offline
Old 06-04-2012, 02:57 PM
smitten
smitten's Avatar
I used both (raamat) and thought it worked well. The Raamat was easier to install than I thought it would be.
smitten is offline
Old 06-04-2012, 09:15 PM
BuckeyeDemon
BuckeyeDemon's Avatar
if you are talking about the thin (1/8") butyl/asphalt based product, then think of that as a replacement for the thick sound deadening material the factory sprayed on parts of the floor pans and parts of the rear quarter panel on the inside. it's meant to damp vibration in the panel by adding mass.
BuckeyeDemon is offline
baddog671
07-26-2016 01:20 PM
Dokilar
15
10-16-2015 08:13 PM
winner99
10-01-2015 10:52 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: DynaMat (or similar product) + OEM insulation? Or just one?
