new to the "classic" world of Mustangs
Hey guys,
just picked up a project car for the wife, she's always wanted a '66 mustang so we started looking around for one. we finally found a viable candidate in the form of a 6 cyl, 3 speed manual car. it does have some rust issues but the "bones" of the car are solid so that's a plus. this will be a full on resto-mod. pretty much stripped down to parade rest and rebuilt, new fuel and brake lines, new tank, new suspension components, etc, etc.
I'm letting her make most of the calls on how this will be built but I will retain the decisions with reqard to safety and drivability.
here is a list of what she wants:
small V-8 (maybe fuel injected)
auto tranny
A/C
5 Lug wheels
power steering
disk brakes
she wants to keep the exterior and interior looking stock (for the most part).
I know everyone will say it's better to start with a V-8 car but in our area it's hard enough to find a decent 6 cyl. much less a V-8 car.
I'll be replacing both rear quarters due to the previous owner attempting to "fix" them and doing it wrong, I'll also be replacing the tail light panel and trunk lid, then probably door skins as well. notice I didn't mention the floor pans or any structural parts, that's because they are pristine.
question 1: I'm thinking about picking up a nice 4.6 and an auto from a modern car (along with the harness and computer) and transplanting them into this car. is this doable and what should I look out for?
question 2: since I'm going to replace all the suspension components anyway, I'm assuming I can just buy new parts for a 5 lug car and bolt them into the body, am I on the right path?
question 3: can I do the same thing for the power steering or would it be better to transplant a system from a different kind of car into the stang body??
question 4: I think I'll have to replace the rear end to get the 5 lug setup or can I just replace the axles and rebuild the center section?? if replacement, what should I look for as a transplant organ??
that should be enough to keep you thinking for a while.
thanks in advance for any advice.
auto tranny
A/C
5 Lug wheels
power steering
disk brakes
1. You will need a mustang II style front suspension for the 4.6.
2. You could do that. If you don't go power steering you will also need v8 steering components.
3.They make kits to convert to power steering.
4. You will need a new rear end and driveshaft.
Location: Detroit; where the weak are killed and eaten.
Only advise would be one project at a time unless you plan on not driving it for quite some time. Seems we always get tied up or money runs out for awhile and then it sits in the garage and you don't have anything to drive.
NorthAmericanTuning
11-09-2016 11:45 AM
Joolander
05-02-2016 02:28 AM
NorthAmericanTuning
03-18-2016 11:21 AM
raven_ghostwolf
08-16-2015 08:16 PM
