correct matching of the transmission and differential - MustangForums.com
Old 05-18-2014, 10:54 AM   #1
michaeluy
michaeluy's Avatar
Default correct matching of the transmission and differential
Hi,
I own a '71 Ford Mustang Mach 1,
I'd like to know the correct matching of the transmission and differential.
Currently, my differential and transmission don't match.
Thanks,
Mike
michaeluy is offline   Reply With Quote
Old 05-19-2014, 10:24 AM   #2
michaeluy
michaeluy's Avatar
Additional details:
351 Engine - Cleveland
Automatic Transmission C-6
Main Question: Compatible Ratio of Gears to Differential Gears for an automatic transmission C-6
Thanks
Old 05-19-2014, 02:57 PM   #3
69mach1377
69mach1377's Avatar
What does the door tag say they should be?
69mach1377 is offline   Reply With Quote
Old 05-19-2014, 10:41 PM   #4
michaeluy
michaeluy's Avatar
Hi 69mach1377,
When we acquired the car, it was formerly fitted with a automatic C4 transmission which matched with the differential gears.
The transmission was later changed to a C6 automatic transmission which now did not match with the differential.
The door tag specs were those of the C4 transmission
So I guess the question is: What is the correct gear ratio for the differential of my '71 Mustang Mach 1 (Cleveland) with C6 automatic transmission?
Thanks,
Mike
Old 05-22-2014, 11:05 AM   #5
69mach1377
69mach1377's Avatar
Not sure it matters...the c4 and c6 probably have the same 1st, 2nd and 3rd gear ratios anyway. The difference is their ability to hold engine power with the c6 being stronger.
Old 06-03-2014, 04:59 PM   #6
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
What do you mean it doesn't match? Do you mean not original?
I have a very not-original 351w with a C6 running on a peg-legged 8" w/ the 2.80 rear end. It isn't correct but it will absolutely scald the **** out of the tire doing the one wheel squeal.
As far as I know almost all rear axle ratios were available with either transmission. Maybe if you get into the hi-po stuff there were some limitations but by and large you could get any axle ratio you wanted depending on a few variables like whether your car has air conditioning
*sigh*
I really need to get off my *** and put in my trac-loc chunk.
fastbackford351 is offline   Reply With Quote
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 07:23 AM
What other parts should I be concerned about if my pinion bearing went bad? KingRando 2005-2014 Mustangs 5 10-02-2015 09:06 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 06:26 PM
Need to rebuild the automatic transmission 1996 GT wraith777 General Tech 1 09-28-2015 11:49 AM
