Difference in oil senders 65 to 66?
Old 06-25-2014, 07:33 AM
wunderwerks
wunderwerks's Avatar
Default Difference in oil senders 65 to 66?
Other than the stud vs spade connection to the wiring harness, is there any difference in the internal workings of the two different types of senders. I believe the stud was intended for the gauges and the spade was intended for the oil lights.
wunderwerks is offline
Old 06-26-2014, 09:16 PM
wunderwerks
Default Clarifying the question
Could I successfully use a 66 sending unit on a 65 with an oil light? The new engine wiring harness came in a package stamped 65 with lamps but the connection is for a stud sending unit. Suggestions?
Old 06-27-2014, 09:14 AM
bop11
bop11's Avatar
The 65 is a switch and the 66 is a variable resistor which will make the light glow at different levels and drive you nuts.
bop11 is offline
Old 06-27-2014, 04:11 PM
wunderwerks
That's the answer I was looking for. I'm going to have to replace the oil sender end of the new harness with a spade connector. Thanks for replying.
Old 06-28-2014, 08:40 AM
69mach1377
69mach1377's Avatar
If you really want to know your oil pressure, get a mechanical gage.
69mach1377 is offline
fcarpio
Suspension
11-16-2018 10:35 AM
Shadow7874
09-24-2015 09:06 PM
Demodulates
09-18-2015 11:14 AM
kevsgt
09-09-2015 06:20 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Difference in oil senders 65 to 66?
