1967 mustang fastback
Old 08-24-2015, 12:51 AM
Bullet 67
Bullet 67's Avatar
Default 1967 mustang fastback
Is there a way to reset the drivers side door latch without taking the whole assembly out? The (I'll call them clam shells) on the door latch have gotten stuck in the closed position and the door can not be closed. Lifting up on the door handle or pushing on the outside door button make no difference. What do I need to do please?
Bullet 67 is offline
Old 08-24-2015, 10:57 AM
boogerschnot
boogerschnot's Avatar
Sounds like the latch is closed and locked. Try unlocking the doors using the key? If that doesnt work, pull the door panel and look in to see if something is binded.
boogerschnot is offline
Old 08-24-2015, 12:20 PM
Oak
Oak's Avatar
Sorry dont mean to highjack, BOOGER where are some progress pics???? Grandma was slow but she had an wxcuse LOL
Oak is offline
Old 08-25-2015, 12:12 AM
Bullet 67
Bullet 67's Avatar
Default 1967 fastback
thank you boogerschnot for ur suggestions. I will try again using the key. I was hoping there was a release lever or some other way to reset the door latch. Have a gr8 day.
Old 09-02-2015, 10:00 AM
bop11
bop11's Avatar
It is fairly easy to remove the door latch once the inner panel is removed. 3 screws and unhook the rods. No need to remove the window or anything else. Of course small hands would help, but I have large ones and was able to do it. There are 3 springs on the latch. 2 are easy to see and replace, the third is not. It is a small flat wound spring that keeps the lock rod from dropping by its own weight. Every time we closed the drivers door it would automatically lock because the spring had rusted away. We had to replace the latch, which is not expensive, since this spring is not available alone.
If you pull up on the lock rod, you should be able to force the latch jaws open, without removal of the latch.
bop11 is offline
Old 09-03-2015, 07:20 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
I seem to remember dealing with this a long time ago and I think all I had to do was use a screwdriver or something to manually pop the "clam shells" back to the open position.
fastbackford351 is offline
Old 09-03-2015, 11:25 PM
Bullet 67
Bullet 67's Avatar
Thank you both fastbackford351 and Bop11. Both are good suggestions. I tried prying the "clam shells" with a screwdriver and had no luck. I also tried pulling up on the inside door handle as well as the outside door button and used the key as well. None of these efforts got the door latch to open. I think what I need to do next is check out all of the components inside the door the connect to the door latch. Any suggestions on how best to do that are appreciated. Again thank you Bop11 for your description of the springs on the door latch. Is there a place to find a schematic or some step by step directions about how to take apart and reassemble all of the components involved with this door latch?
Old 09-04-2015, 12:18 AM
AK_Kayaker
AK_Kayaker's Avatar
There may be more, and better, but these looked promising.
dooe assembly vids
door assembly pics
AK_Kayaker is offline
Old 09-18-2015, 08:00 AM
bop11
bop11's Avatar
Just noticed , you said you "tried prying the clam shells with no luck". When you were doing this, did you have the inner door handle lifted or the outer button pushed? Prying won't work with out doing either of those, as the whole thing about the latch is to keep the door closed unless a handle is activated.
Did you get the latch out?
bop11 is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
NTO_GUY
12-24-2015 11:23 AM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1967 mustang fastback
