LED instrument gauges problem 1967 fastback
Old 09-21-2015, 07:09 PM
andrew1969
andrew1969's Avatar
Default LED instrument gauges problem 1967 fastback
Hi guys,
I have just replaced the incandescent bulbs with led bulbs in my instrument gauge cluster and now the car won't start. my battery is fine.
does anyone know why the led lights are causing my car not to start?
thanks for any help offered.
andrew
andrew1969 is offline
Old 09-22-2015, 09:31 AM
69mach1377
69mach1377's Avatar
That's weird. The only led issue I've heard of is hyper flashing of turn signals, which requires resistors to be added.
Good luck.
69mach1377 is offline
Old 09-22-2015, 03:05 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
I can't imagine why led's would cause your no-start problem. I'd be more inclined to believe that something didn't get hooked back up correctly when you pulled the cluster out.
fastbackford351 is offline
Old 09-22-2015, 05:40 PM
andrew1969
andrew1969's Avatar
thanks guys.
I know it's weird. i plugged the 3 plugs behind the cluster back in and the leds lit up but the car would not start. i removed the bulbs and the car starts. very strange.
could the leds be drawing so much current that the car has not got enough power to turn the starter motor? even though leds are supposed to use less energy.
Old 09-23-2015, 07:43 AM
fastbackford351
Foghorn Leghorn
Damn. That is a noodler.
Are you putting the incandescent bulbs back in to start it up or leaving them out altogether?
Old 09-23-2015, 09:14 AM
69mach1377
69mach1377's Avatar
LEDs should be drawing less current IIRC. They might be altering the voltage seen down the line? Electricity is not my strong point...
Old 09-23-2015, 05:29 PM
andrew1969
andrew1969's Avatar
i removed the instrument fuse in order to start the car.
i have no idea what the issue could be!
Old 09-24-2015, 09:21 AM
fastbackford351
Foghorn Leghorn
If you replace the leds back with the incandescent bulbs do you get the same results?
Trying to eat the elephant one bite at a time here. If you put the incandescent bulbs back in and have the same results then the problem isn't with the LED's.
Old 09-25-2015, 03:44 PM
andrew1969
andrew1969's Avatar
with the old bulbs back in, it starts fine...
very puzzled.
Old 09-25-2015, 06:41 PM
fastbackford351
Foghorn Leghorn
Now take the bulbs out altogether and see what happens.
Quick Reply: LED instrument gauges problem 1967 fastback
