need expert opinions
Old 06-15-2016, 03:18 PM
rickieh
rickieh's Avatar
Default need expert opinions
http://s151.photobucket.com/user/wil...ang%20fastback
I purchased this 1969 mustang in running and driving condition, all it needed was a bit of brake work. Im local law enforcement where I live so I was able to find out a bit about the car before I bought it. I am the 3rd owner. a lady in DC owned it for nearly 50 years then it was purchased by a gentleman in VA then by yours truly. What I cant verify however is the milage. The story Im getting is that until the guy in VA bought it the original owner kept it in a barn for nearly 40 of her years of ownership. The odometer reads 3328 now and the title I received/have states "Actual Milage:3325" but Im aware theres not a whole lot of ways to tell if the odometer has rolled over. This is where the more experienced folk come in, based on these pictures does this look like a barn find with only 3328 miles or does it look like a road car with 103,328?
Thanks,Rick
rickieh is offline
Old 06-15-2016, 03:26 PM
rickieh
rickieh's Avatar
*cant find edit button*
Also Im aware this is not the original tank, I have the original tank and air cleaner
rickieh is offline
Old 06-15-2016, 08:35 PM
SSRFUZZY
SSRFUZZY's Avatar
from looking at the pics. I would lean towards the later for the following reasons.
*Carpet is far too deteriorated for only 3300 miles even being stored in a barn.
*The body appears to have been repainted at some point. (white paint on rockers pealed off revealing blue paint underneath)
*Underside has way too much road grime build up for so few miles.
*interior is quite faded for having been inside a barn
*amount of rust under car could be be conducive to the type of floor or lack of in the the barn. (40 yrs on limestone will do this) or it's been out side more than they are telling you.
*the rust in the corners of the door aren't consistent with having been stored in a barn. (under an open air lean too maybe, indoors no)
But those are just my observations and opinion.
SSRFUZZY is offline
Old 06-15-2016, 11:21 PM
Gun Jam
Moderator
Gun Jam's Avatar
I found the rust surprising too.
Things that can been good indicators
The drivers door: How much wear is on the bear claw latch post?
The mechanisim that keeps the door open uses two rollers? Is there any noticeable wear on them?
When the door is open and you lift up on it is there any vertical play?
What belts are on the engine?
What air cleaner element is is the air cleaner box?
I also think its got over 100k on it as well
-Gun
Gun Jam is offline
Old 06-16-2016, 10:40 AM
movielover40
movielover40's Avatar
I would think it has 103,000 on it.
movielover40 is offline
Old 06-17-2016, 10:04 AM
69mach1377
69mach1377's Avatar
Odds are over 100k for a car this old that looks like that...
69mach1377 is offline
Old 06-17-2016, 12:41 PM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
Location: I reside in a near constant state of amazment.
pedal wear is a good indicator
fastbackford351 is offline
Old 06-17-2016, 03:10 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Pedal wear and wear under of the carpet under the pedals. Older carpet is not as durable as today's carpet and it will have tell-tale heel marks unless it has only 3300 miles.
Derf00 is offline
Old 06-18-2016, 04:28 AM
rickieh
rickieh's Avatar
the door play is minimal. door edge lifts up maybe 1/4 inch. would a carfax tell it for sure? or a marti report? what exactly is a marti report
rickieh is offline
Old 06-18-2016, 10:07 AM
69mach1377
69mach1377's Avatar
Give it up man...it's wishful thinking.
Quick Reply: need expert opinions
