Instrument Lights wont wo
I have a 65 Mustang coupe. My intrument lights were working and then all of a sudden stopped. I have changed the fuse with no luck. When I check the fuse box with the meter I don't show any power. When I check other places in the fuse box the rest works. Any Ideas would be greatly appreciated.</P>
Thanks </P>
David</P>
O.K.-3 things come to mind: 1) The headlight switch is bad-(probably not likely if the headlights work, but a possibility) 2)The constant voltage regulator behind the dash is bad 3)like the previous post-bad ground somewhere.</P>
</P>
I had a 71 Ranchero that the headlights worked but the dash and tail lights didn't. The light switch was the problem, try turning on the lights and wiggling the **** to see if you can make contact.</P>
Quig</P>
</P>
Ok I have checked the voltage regulator on the back of the instrument panel and its checks out fine. I can't find where the bad ground might be. I have not changed the headlight switch, it does turn the headlights and tail lights on. </P>
</P>
Thanks David</P>
</P>
RE: Instrument Lights wont wo
Since the wires under you dah are old you can start replacing wires. Electrical is not my strong point so I use the ameteur method of replacing wires until whatever wasn't working works again. Not the best way to do it but it's cheap and easy.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
