screech
Old 03-07-2004, 11:05 PM
hoeth18
hoeth18's Avatar
Default screech
when i push gas pedel down hard the car screechs. just had starter replaced forthe 5th time and just put a heat shield on. Anyone know why/what is screeching.
hoeth18 is offline
Old 03-08-2004, 02:03 AM
red347
red347's Avatar
Default RE: screech
It sounds like the starter is a little "cocked" out of position. Loosen the bolts, move it away from the flywheel a bit, and re-tighten. Mine use to do the same thing. Make sure it is TIGHT so it will not move again. It may take a few tries to get it just right.
Ron
red347 is offline
Old 03-09-2004, 01:19 AM
68GEETEE
68GEETEE's Avatar
Default RE: screech
make sure your starter has the correct nose cone for your application. a starter for a manual trans is different from an automatic as the nose cones are different.
68GEETEE is offline
Old 03-09-2004, 01:21 AM
68GEETEE
68GEETEE's Avatar
Default RE: screech
to add to this, you need to get a starter for the engine year, which may be different from the body year. I had a '67 Mustang, but it needed a starter from a '74 to work as someone changed out the motor at some point.
68GEETEE is offline
Old 03-09-2004, 08:49 PM
bigchalupa
bigchalupa's Avatar
Default RE: screech
Are you sure its the starter? Mine used to screech because of the fanbelt slipping, but that doesnt sound like its your case
bigchalupa is offline
Old 03-11-2004, 05:02 AM
/77ustang_Guy
/77ustang_Guy's Avatar
Default RE: screech
well i'm not too sure but my car used to do the same thing and it turned out to be the alternator. it was so old that it started getting stiff...i bought a new one and haven't had any problems since.
/77ustang_Guy is offline
Old 03-15-2004, 09:09 PM
bob emmerich
bob emmerich's Avatar
Default RE: screech
I would say it sounds like a loose belt. The starter is only used when cranking the car to start it. After the car starts, the starter pretty much doesn't do anything. I would go with replacing the belt.
bob emmerich is offline
Old 03-15-2004, 09:45 PM
red347
red347's Avatar
Default RE: screech
Something that bothers me here though...5 starters? Is this an Automatic? Are the starter and flex plate, or flywheel on a stick, mating up OK? Have you made any other changes? On an Automatic, if the flexplate is loose or "cocked" it could also be making contact with the inside of the bell housing. That will definitely put out a high pitch screetch.
Think thinking out loud...
Ron
red347 is offline
93stallion302
03-15-2007 10:08 PM
203Mach1ne
06-30-2006 10:29 AM
monkeydude3
22
12-17-2005 03:02 PM
MineralMan
07-28-2005 06:42 AM
PonyRider98
21
12-01-2004 01:15 PM
Quick Reply: screech
