Strange Noise
RE: Strange Noise
ORIGINAL: badazz68stang
I just did change the oil with some of that High Mileage ENgine oil, dont know if it really works, but since i changed it over i havent heard the noise since. I usually run Lucas oil products so i guess that would be like the Marvel. Also, a stock 1968 289 is a solid lifter motor correcT?
RE: Strange Noise
Hey Brandon -
I have a '66 289 V8 3-spd and it is behaving very similar to yours. Have you noticed a drop in power\acceleration with your situation? I feel like my car is substantially more sluggish since I noticed the increased noise.
Cheers,
Ziggy
Cheers,
Ziggy
RE: Strange Noise
Your lifters are collapsing, which will give you less lift on the cam and change the timing events. Which, in turn, lowers the power output of the engine. Flush the engine to get the gunk out and put in a good oil. But, it really is time to start thinking rebuild.
ORIGINAL: Ziggysan
Hey Brandon -
Cheers,
Ziggy
Hey Brandon -
Cheers,
Ziggy
RE: Strange Noise
ORIGINAL: Colorado_Mustang
RE: Strange Noise
Thanks y'all.
This is surprising inasmuch as this engine only has 60,000 miles on it. The car did, however, sit for quite a long time unused (but exposed) which wasn't too kind to it.
Anything else I should look for when taking it apart?
AmericanMuscle4.6GT
11-10-2015 02:06 PM
KingRando
10-02-2015 08:06 AM
