Restomod vs. Restoration Prices
RE: Restomod vs. Restoration Prices
ORIGINAL: 67t5ponycoupe
I hope you are not thinking that restorations or restomods are in the 5k ball park. I quit counting at $12,000 on my restomod and I think I'm at about $20,000. I'll add it up when I'm done.
ORIGINAL: 67Sally
But how many of those 500hp 'Stangs do you actually see vs the all original Stickers In Place, Correctly Painted ones? That's why I said that you could spend more on a restomod but for example I won't spend nearly as much as you probably did. 90lx, don't listen to Soaring...he rarely knows what he's talking about
ORIGINAL: Soaring
What do you know? You can't even fix a flat tire. Nah, restomods, depending on the extent you want to take them, are generally a lot more expensive because of the special parts needed. Special parts are more expensive because of the market value. For instance. A 289 engine that gets an overhaul with nothing special but original specs will run you a ton less than a hopped up woopty do 500 HP engine. Another example: A hood for a 65 that is original, but prepped for paint, will run you a ton less than a cowl hood or a shaker hoood. These are just simple examples, but you might get the point. How about that special aftermarket restomod gauge pod?
ORIGINAL: 67Sally
The possibilties with a restomod are endless but the majority of well done originals usually cost more IMO.
