headlight problems
headlight problems
I have a 72 grande and for some reason when i have my headlights on for probably 20-30 minutes they will suddenly turn of for a little bit then come back on and then it keeps doing it and i have no idea why any suggestions?
Check your headlight plugs for poor connections. Next, check the headlight switch itself. If you can find no problems, you may have a short, or you may need to replace the switch. I believe the switch has a built-in circuit breaker. An intermittent short would trip the breaker intermittently.
ccdguy
09-19-2015 05:20 PM
