1973 Mach 1
Old 08-08-2006, 04:34 PM
1970muggzi
1970muggzi's Avatar
Default RE: 1973 Mach 1
Well it may be a 73 Mach1 but it has a 71-72 stripe kit on it, so to make it correct you would have to change that. Though personally I think the 73 stripe kit sucks. My 73 mach1 is getting a 71-72 stripe kit, they look better. Also the Magnum 500 Rims are 70 to 72 so not correct to the car, the 73 rims were aluminium slotted style rims. But here again the Magnum 500's look better, and match the 71-72 striping, so you could easily leave that alone too !
As far as the cracking in the paint, that is suspicious to me. Why is it cracking ? Paint doen't just crack like that. is there bondo (mud) underneath where the cracks are ? Was the car hit ?
Run a magnet over the sheet metal, to see how much bondo is in it. It could be a 3 dressed up like nine ! It's amazing what paint can hide remember.
If it's a Southern car you should be relatively safe with the rust issues, but ANY of the frame or frame rails, or floorpans are rusted, stay away. That is a super xpensive fix, and it will mean the car has other problems compounding the "fix it" costs.
Don't buy sight unseen.
Be realistic and safe.
It is a good deal, but be suspicious why.
Mach1steve
www.muggziperformance.com
1970muggzi is offline
Old 08-08-2006, 04:42 PM
Soaring
I ♥ Acer
Soaring's Avatar
Yeah, that is easily a 15K car if going only by the pictures. There has to be a reason for the cheap price.
Soaring is offline
Old 08-08-2006, 09:47 PM
dcohen
dcohen's Avatar
i got a 72 mach 1 with a 302 2 bbl for 400 bucks[8D]
dcohen is offline
Old 08-08-2006, 10:17 PM
Ridiculon4000
Ridiculon4000's Avatar
Dude, I'd buy that for that price and be tickled pink with the divorce it caused me to get![8D]
Ridiculon4000 is offline
Old 08-09-2006, 12:40 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
i would be leary of that price? is it a second chance auction? i would report it to ebay if so! sounds to good to be true[:'(] the auction leaves a bad taste in my mouth! i wouldnt lay down cash till i saw the car in person if they can produce a title or have a policeman run a check of thye vin to make sure it comes back clean!
rmodel65 is offline
Old 08-09-2006, 12:42 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
and for the cracks its either too much materials on the surface from past paint jobs or its rust rearing its ugly head from under the bodyfiller!
rmodel65 is offline
Old 08-09-2006, 02:12 AM
Smothers
Smothers's Avatar
Did you buy it?
Smothers is offline
Old 08-09-2006, 12:21 PM
jrrhd73must
jrrhd73must's Avatar
ORIGINAL: 1970muggzi
Well it may be a 73 Mach1 but it has a 71-72 stripe kit on it, so to make it correct you would have to change that. Though personally I think the 73 stripe kit sucks. My 73 mach1 is getting a 71-72 stripe kit, they look better. Also the Magnum 500 Rims are 70 to 72 so not correct to the car, the 73 rims were aluminium slotted style rims. Mach1steve
My 73 originally came in 1973 with the 71-72 stripe kit. So you are incorrect as to make it correct. There is virtually no way to tell unless you have a photo with the window sticker and them picking it up from the dealer. Ford uses the remaining parts on the assembly line until they run out then they move to the next years parts. I have had this happen on 3 of my Fords.
I am pretty sure the Magnum 500s were an option that year.
jrrhd73must is offline
Old 08-10-2006, 01:42 AM
smoyers
smoyers's Avatar
It was a ebay scam. This guy emailed me through ebay and said that if I wanted it it was mine. But then he wouldn't let me come see it before I bought it. He said he was in London on a trip. I looked closer at the ebay ad and saw that the seller put a phone number on there. So I called him and he had already sold it. And said he has never been to London. Don't know how this guy did it but he almost had me.
smoyers is offline
Old 08-10-2006, 02:26 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
make sure u report him! the second chance auction someone sent me was on the same trip i quess? he was in england supposedly. if u ever get a second chance auction it will show up in ur myebay page!!!!!
rmodel65 is offline
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
mustangheaven
01-03-2016 11:20 AM
mustangheaven
10-07-2015 10:23 AM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
Quick Reply: 1973 Mach 1
