lower radiator hose replacement
hey fellas,
i am replacing my lower radiator hose because it was all rotted and had holes in it. it was a B!tch to get out and now its being a even bigger B!itch to get back in. can anyone give me any pointers please? OH, and its on a 68" stang, Thanks!
RE: lower radiator hose replacement
Yes, that clamp is a tough one to get on, isn't it? I wound up using several extensions on my ratchet, and used a 5/16 " socket to go from the top. I tried tightening the clamp from the bottom, but that didn't work because I couldn't get a good angle with either a screw driver or the socket.
In the fututre, when removing hoses, try just taking a utility knife and cutting a slit in the end of the hose. This usually lossens the hose just enough that it will slide off with little effort.
Dragonus18
09-09-2015 01:21 AM
