'65 289 trouble contd...
Old 06-23-2004, 02:40 PM
musthaveTang
musthaveTang's Avatar
Default '65 289 trouble contd...
hey guys,
i wrote a week or so back about trouble with my '65 289 pony. it started burning oil and running very very ragged. i mean it stalls unless i run it at high revs. and you suggested that the head gaskets might be blown and that i should strt with a compression test.. well i did the compression test and here are the results:
150-152 psi in all cyclinders except the driver-side forward most cylinder which read 122psi
are these figures in the OK range? is there anything else that i can do before i take it to a shop?
thanks for your time.
vamsi
musthaveTang is offline
Old 06-24-2004, 12:33 AM
68GEETEE
68GEETEE's Avatar
Default RE: '65 289 trouble contd...
your number 5 cylinder either has a worn ring, or possibly damage to an intake or exhaust valve.
http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
68GEETEE is offline
CS2007
06-25-2019 09:45 PM
uberstang1
12-07-2017 07:10 AM
chrisdbassplayer
10-13-2015 06:53 PM
GTJIM
09-23-2015 09:59 AM
ryland
09-13-2015 12:35 PM
Quick Reply: '65 289 trouble contd...
