PVC breather?
PVC breather?
I have the little breather cap on my valvecovers now and I was told gettign a PVC would be better? Anyone know the beneifts of this and wether its difficult? I have no idea what a PVC does..
RE: PVC breather?
PVC is Polyvinyl Chloride, it is used primarily for making pipe. You are wanting a PCV valve, which is Positive Crankcase Ventilation. It allows your crankcase to vent. the breather you have serves the same purpose as a PCV valve, I dont think there would be an advantage to getting a PCV valve, but maybe someone else knows of one.
RE: PVC breather?
well rather ehat the gasses coming out under presure the pcv valve connectc to a vaccum eliminating gasses that build up in your crank case and aslo in my 67 atleast runs alot smoother with a pcv and i don't get oil leaks i would say use one and they are cheap
