Need Help Bad!!!
Need Help Bad!!!
i really need help, im confused. I went to bolt up the new flywheel for the 351 and two of the bolts didnt line up. I checked out the old flywheel that the previous owner put in when he converted it to manual. The numbers on it says its for a 289. The new flywheel is from cj pony parts and says its for the 302/351. Any idea on why the bolt patterns are different and what flywheel should i be looking for. btw, i counted the teeth with the new one having 157 and the old one 160. Thnaks for any help
RE: Need Help Bad!!!
Keep turning it on the crank snout untill they all line up. They are bored a bit off center on a few of them so it can only go on one way, the right way for the imbalance needed to balance the crank.
Rotate it around untill they all line up.. its like a puzzle
KingRando
10-02-2015 08:06 AM
GT350 S550 Tech
09-29-2015 03:29 PM
